Two hydraulic questions
/ Two hydraulic questions #1
rockinmywaypa
under the elephant\'s tail [ ontario can.]
john deere 3130, universal case 970 and a IH 1086
Question #1
I purchased a used 3 spool valve which has an extra port that I'm not familiar with. Would it be part of the pressure relief but using an extra line to return to tank or might it be for a power beyond type of application. It is located right beside the outlet port. What purpose does this port serve?
Question # 2
I have a hydraulic motor that has been used on a self propelled forage wagon which I am converting back to pull type but I still want to have hydraulic drive via long hoses. On this motor there is a small hose fitting that is barbed so it obviously cant handle much pressure and it was ported back to the resovoir tank.You can see it located near the sprockets driving the wagon. I need a pump anyway and thought I would use this motor as a pump if I can but I don't know what use this nipple is for. I don't want it as a motor unless that nipple does nothing since I don't want an extra line to drag when using it. Can somebody tell me if I can use this as a pump and what reason there is for that line out to the tank.
/ Two hydraulic questions #2
I believe the purpose of that nipple is to return any leakage past the primary hi pressure shaft seal back to sump. That way you dont slowly lose hyd fluid from functionally inconsequential leaks.
...larry
/ Two hydraulic questions #3
Question #1
Question # 2
The center adapter is probably your PB adapter. It looks looks someone was using it in the PB mode. It is also called a high pressure carry over.
The small third hose on the hyd motor s probably the case drain and either goes back to pump case or the tank.
Those fittings also look like water pipe fittings, and may not with stand the hyd pressure.
It is doubtful that you can use that hyd motor as a pump.
/ Two hydraulic questions #5
I don't think so, as it may blow the shaft seals.
Excerpt:
Seal Failure
High case pressure results in excessive load on the lip of the shaft seal. This causes the seal lip to wear a groove in the shaft, eventually resulting in leakage past the seal. If case pressure exceeds the shaft seal’s design limits, instantaneous failure can occur. The subsequent loss of oil from the case may result in damage through inadequate lubrication.
/ Two hydraulic questions #6
I think the big port on the end of your valve is Power beyond. I think the smaller one is the return to tank line. If you do not want to use the PB you need a special plug and you need the return line to tank.
You also cannot plug a case drain line on a hyd motor.
Thanks for the advise. I wonder where I would look to find the right plug to block the valve port since power beyond won't be needed or used in the application I have planned for it.
/ Two hydraulic questions #8
From the picture, it looks to be a Gresen valve. I think they were taken over by Parker Hanifin. You could try here for starters:
Contact
Hydraulic Valve Division
520 Ternes Ave
Elyria OH
UNITED STATES
44036-4026
Ph: (440) 366-5100
Fax: (440) 366-5253
HVDSALES@PARKER.COM
I have a valve similar to yours, but it doen't have all of the ports you ask about, although it is a 3 lever.
/ Two hydraulic questions #9
You will be able to modify the PB port adapter to standard usage....
Unscrew the adapter and expose the innards......if it is indeed a PB adapter then you will see internally that it separtates the inner pressure core with the return ports......all that is needed is the cut/machine off the area of the PB adapter that extends into the chamber (shorten it)....
the standard adapter is about half the length....
/ Two hydraulic questions #10
Take the fitting out ans take it to a hyd shop and they can match it for a hex plug. What you are doing is converting back so the total fluid and the expended fluid will flow out the OUT/tank port.
What kind of hyd valves are on your tractor now?
If you are going to add any valve downstream, you should use the PB outlet, even to feed the 3pt. or maybe a remote valve later.
Just run the OUT/TANK hose to tank, and PB port to the next valve.
/ Two hydraulic questions #11
If you have no use for the Powerbeyond now but think you may use later then connect those to outlet together with short hoses and "T" fitting then run it to tank. Later on if you wish to connect another valve in the system, disconnect hose from the Powerbeyond and run it to the other valve.
JJ
The intended purpose is going to be a silage stuffer similar in end result to an agway bagger but I am using a garbage compactor principle to achieve the packing. I am planning a square pusher operating like a wood splitter, in and out that the feed will drop down in front of when it's back and builds up on top as it cycles. I will be adding a valve that has an automatic flipper downstream to cycle the cylinder similar to a hydraulic manure pump but I want these valves to turn everything on and off. I will have a hydraulic motor powering the wagon and another motor powering a conveyor loading the hopper chamber. I have one flow control and need another yet to control unloading volume entering the chamber. So far I have picked up most of what I need if I can make it all work together. That motor pictured can be used on the conveyor and it will be stationary enough not to cause a problem with an extra drain hose.
/ Two hydraulic questions #13
Don't know where in the flow path you will put the PB valve, but all the valves that feed downstream operations should have PB.
Certain operations should be thought out, so if using a valve up stream, it could use all the fluid and none for the other valves.
If you have to split some circuits, you can do that also to insure delivery.
They make a priority valve for something like this, to ensure the important functions have fluid available.
New/Unused AGT Flail Mower for Excavator (A61166)
New/Unused AGT...
Freighliner Tender Truck (A63118)
Freighliner Tender...
Columbo Twin Master (A62177)
Columbo Twin...
2018 Dodge Charger Sedan (A61569)
2018 Dodge Charger...
New/Unused Wolverine Mini Skid Steer 3 in 1 Bucket (A61166)
New/Unused...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
