Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,672
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
The way I do mine is to shut the tractor down. This allows me to turn the tractor pto shaft CCW easily. I hold the chipper shaft in position and push in with the right hand not worrying about the ring while turning the tractor pto shaft with my left hand fingers. When the splines are aligned the chipper shaft will start to seat. Then use nspec's method of hooking your thumbs or heels of your palms on the coupling and pulling back the ring with the fingers of both hands and push it home. In some ways it is easier than the button type. Just be sure you have it started before you start pulling the ring back.
