CK30 Preheater controller
/ CK30 Preheater controller #1
Steve_Miller
Nova Scotia, Canada
2006 Kioti CK30HST
Anyone know what exactly the preheater controller does? Does it control another relay that actually powers the glow plugs for a predetermined time? Having trouble with this circuit, I have no glow plugs at the moment (starting with my heatgun shoved in the air intake). I've tapped (aggressively) on the controller box and it fired the glow plugs and started once but haven't got it to do that again. Glow plugs are fine, light on dash comes on like it is timing. I'm out of warranty so I'm trying to troubleshoot on my own. I have the copy of the service manual that someone provided online here a year or to back but it is not exactly the same layout on the firewall as mine. Any help would be greatly appreciated.
Thanks
Steve
/ CK30 Preheater controller #2
This is how it works on the Bobcat verison. I presume it is the same.
The preheat controller is a timer. It sends a signal, which passes through a fuse, to activate the glow plug relay. The output from the relay sends voltage to the glow plugs but also lights the indicator light in the dash. If the glow plug indicator light is coming on the relay is working.
/ CK30 Preheater controller #3
Mine didn't.
The glow indicator plug light would come on in the dash of my DK 35, but I had no power to the glow plugs.
My preheat controler was bad. I replaced it with a new one and its been fine ever since.
/ CK30 Preheater controller #4
Mine didn't.
I know Bobcat had quite a few design changes made in the electrical system, this must be another one of those. The Bobcat feeds the indicator light after the relay.
My glow plug relay is bad, i can tap on it and it will work for a time or two then stop working again. It energizes but does not make contact closure to the plugs. My preheat controller controls the glow plug relay. If the coolant sensor in the engine block is above 30 degrees (Celsius) the glow plug relay and light will not come on. If the temp is below that they both energize (two separate outputs from the controller).
Steve
2003 VOLVO G720B MOTOR GRADER (A66091)
2003 VOLVO G720B...
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
2013 Ford F-350 4x4 Crew Cab Pickup Truck (A64556)
2013 Ford F-350...
Hydraulic Auger Mini Skid Steer Attachment (A64553)
Hydraulic Auger...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
