Backhoe Bxpanded backhoe dolly
/ Bxpanded backhoe dolly #1
tmyatt
Westport, Ontario, Canada
Kubota BX 25
Hi all,
I am new to this forum having just (last September) purchased a BX 25 plus a mowing deck and 60" plow. Hope to get more attachments as time and $ allow. What a great tractor! I am now becoming proficient at removing and installing the backhoe but saw the video of the Bxpanded backhoe dolly which made removal and installation look even easier plus, the added advantage of moving and easier storing. Since I have blown the budget on purchasing the tractor and having the tools to fabricate a dolly, I thought I would make that my winter project. I can work out the dimensions but would appreciate someone letting me know the height and the size of the castors. I am sure I am not the only one to try this and I would rather get it right the first time. Thanks in advance for any information.
Tom
/ Bxpanded backhoe dolly #3
Hi all,
Tom
Welcome to TBN. The dolly issue has been around sine 2002..Look around and use the search...You can buy (2) dollies from China frieght for $18 and be 100% happy.
/ Bxpanded backhoe dolly #6
bought one of the BX expanded dolly's for my BX 25 back hoe and I'm very happy with it. It is well made, allows me to easily remove the back hoe and once quickly on the dolly I can move it around the shop.
/ Bxpanded backhoe dolly #7
Here is one I built from free tubing!
Looks very familiar....
I did buy NICE phenolic casters. I think 800 lb since you put a lot of weight on the small end when removing.
Deano, Nice work, I hope I can do the same. Can you tell me the height of the dolly? My backhoe is off the tractor and stored for the winter otherwise I would instal and measure height. Thanks,
Tom
/ Bxpanded backhoe dolly #9
Oh my, that does look familiar, almost the same as the grey one I have. ;)
It reminds me - to the original poster - you probably want to make the one end solid casters and the other end swiveling... prevents it from rolling off if not on a perfectly level surface.
/ Bxpanded backhoe dolly #10
Correct on swiveling casters!:thumbsup:
/ Bxpanded backhoe dolly #11
Tom
See email I sent!
/ Bxpanded backhoe dolly #12
I have the BXpanded version and actually replaced the fixed castors with swivel versions (from Lowes) since I need to remove and then rotate the BH 180* in it's own footprint. Couldn't do that with the fixed castors. As long as at least two of them have brakes, I think he'll be set.
/ Bxpanded backhoe dolly #13
That's a pretty good idea - use ones with brakes! I actually rotate mine 180 also when storing. It's a bit of a pain, and I certainly can't do it in it's own footprint.
/ Bxpanded backhoe dolly #14
Here's a pic of mine in storage so you see what I mean about tight storage. Pic is from last winter. It's tighter now with a log splitter in the right corner and the loader turned around and in the middle. I now back he tractor in and the 3PH fits inside the loader bucket.
/ Bxpanded backhoe dolly #15
Has that stuff been used?? Much too clean.:eek:
/ Bxpanded backhoe dolly #16
In that pic, no. Pic was taken a few days after delivery last winter. The backhoe sat in storage until about April. The loader was put to work about a week later clearing record snows for Jan. 2011 - more than the blade could "relocate".
I knew someone was gonna point that out. :laughing:
/ Bxpanded backhoe dolly #17
I was not trying to make fun of you, I was impressed.
Who made your stands?
/ Bxpanded backhoe dolly #18
I made a backhoe dolly for my bx24 out of a left-over length of lam-beam & 3 tool chest casters. Cut the beam & bolted it together in a T shape, & put the 3 wheels on the bottom. Was one of those rare projects where everything worked out just right the 1st time, took all of about 30 min & works perfect. Fast on & off, small footprint, & sturdy too.
All wheels need to swivel to make it easy to reinstall, or else you'll need a lot of swing room to line it up.
/ Bxpanded backhoe dolly #19
Could you please post a picture and a couple of measurements? I would like to know the dimensions of the T. I would also like to know the distance from the floor to the top of the dolly. I tried to make a dolly for my BX23. It looks like the one for the BX25 but it does not work very well so I went back to just letting the backhoe set on the floor when I take it off. It would be nice to be able to move it around.
Thank you,
A.Metcalf
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
Lucknow 360 Feed Wagon (A63688)
Lucknow 360 Feed...
2006 Freightliner Auger Truck (A63688)
2006 Freightliner...
2006 Cadillac Superior 6-Door Limousine, Ultra-Low 20396 Miles (A63688)
2006 Cadillac...
2023 John Deere 8R 310 Tractor (A63111)
2023 John Deere 8R...
Fellabuncher Dangle head, PARTS ONLY (A62679)
Fellabuncher...
