A Little Extra Cab Insulation
   / A Little Extra Cab Insulation #1
High Compression
De Soto, KS
Kubota L5740-3/ Kubota ZD21 pro60
So this is tried and true by yours truly in other equipment, so I thought that I would share. By the way this wasn't my idea, but unfortunately I don't remember where I saw it so I'm sorry for not giving you credit.
This is my new L5740 Grand. Since I had to remove the roof for other mods, I thought I'd go ahead and do the simple insulation install. In some of my other equipment, the roof didn't come off, but the headliner came down and I was able to install the same way. Your just working upside down.:laughing:
I bought this at my local True Value hardware store in the home insulation section. It looks like bubble wrap made of Mylar. It's very thin, pretty cheap and makes a huge difference in your heat and a/c. I think it reflects more energy than actually insulates, but you get the drift.
I used Gorilla tape. It is 100x better than duct tape, but more expensive.
Cut to fit and tape in place. Just that easy.
You'll notice that you have your heater and your a/c turned down the next season. In my opinion, I think they work half as hard.
Does it make your cab noticeably quieter, too?
BOB
Honestly I don't notice a difference in noise insulation. Probably because it is on the roof and not on the floor. I suppose you might not hear the geese flying over after the installation. :laughing:
   / A Little Extra Cab Insulation #4
I have a L5030HTC, how hard is it to remove the liner. I would like to do the same thing but don't have any idea how to remove the liner.
   / A Little Extra Cab Insulation #6
High have you tried your new unit in the cold yet? I doubt you would have needed that done. I've been out in mine in some pretty cold temps lately with just a t shirt on in the cab with the heater fan on low and the mixture turned down on half heat and still found it hot.
My 4240 was the same way. Maybe the older 3030 had a different system that required doing this?
Even with the AC in the summer. You can't keep it up on high in the grand L's because you'd freeze to death with in ten minutes. Hate to die of cold exposure in the dead of the summer :laughing:
Very true! I will say that it is definitely not a necessity on the Grand L's, but I already had the top off, had the insulation left over from my other applications so I figured why not. We do get well over 100 deg F down here in the summer and I have yet to sit in a piece of equipment that will freeze you out in those temps. But the insulation did seem to reflect a lot of the sun's energy and made the a/c work half as hard. Especially when it is mounted in your roof.:laughing:
If your cab is like mine, it is way easier to remove the whole top. I think it is 13 10mm bolts that hold it down from the inside. It's not all of the bolts. Just the ones on either side of the corners, across the front, one in the back middle and a few on the sides. If you take a bolt out it should be long. If you take one out and it is a lot shorter than the others, you can put it back in. The ones across the front are a little shorter that the others but they still have to come out. Keep track. The little short ones only hold the liner. Seriously, with a cordless impact driver or drill driver, you can have the top off by yourself in a couple of min.:thumbsup:
   / A Little Extra Cab Insulation #10
Cool. I understand. I just thought I was missing something. Seeing you had the roof off why not do it. :thumbsup: :cool:
Massey Ferguson 4608 (A53317)
Massey Ferguson...
UNUSED FUTURE 1 SHANK RIPPER (A57193)
UNUSED FUTURE 1...
Caterpillar 906M (A53317)
Caterpillar 906M...
UNUSED FUTURE MINI EXCAVATOR (8) PC ATTACHMENT SET (A57193)
UNUSED FUTURE MINI...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
2008 Honda CR-V SUV (A55853)
2008 Honda CR-V...
