Submersible Well Pump
   / Submersible Well Pump #41
Fracking may seem like a lifeline to some with marginal wells!:D
   / Submersible Well Pump #42
I wish I had written down the pump brand I replaced at my last place. At 275 feet deep in iron rich water, I got 20 years out of it. At around 15 years, the well head got hit by lightning. (The head was about 20 feet away from our bedroom, I liked to have jumped 3 feet in the air) When I finally crawled out, I had no water. With fingers crossed, I headed for the box. The breaker reset and I had water.
I recommend using plastic spacers on the well pipe to keep the pipe and wiring away from the casing.
Lastly, don't scrap out any replaced water pressure tanks. A little work and they make a great chiminea (fire pit). After all your hard work, sit around the chiminea with a couple of beverages and congratulate yourself on a job well done, lol!
   / Submersible Well Pump #43
Apparently, the biggest concern is some of the chemicals pumped down the (fracking) bores and the possibility of them leeching into the ground water.
If the companies follow all the safety precautions, this shouldn't be a problem. But sometimes safety gets in the way of profits.
   / Submersible Well Pump #44
reminds me of the erin brokovich story (spelling? )
soundguy
   / Submersible Well Pump #45
I have seen a Crude Oil contaminated water well.:)
I have also seen water wells containing methane. In fact I had one. No contamination from the hydro carbon industry.:)
I have also watched "Fire Down Below".:)
And some of the Anti Fracking websites.:confused: Their documentation had me confused.:confused:
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
