Lincoln weldanpower with a LN-7?
   / Lincoln weldanpower with a LN-7? #1
db556
Pittsburgh
Jeep Wrangler / gravely 5240
Well I got a LN-7GMA from work for free the other day :thumbsup: it needs some paint, a gun, and a feed roll but it works, save for the preflow, and purge/cold feed switch.
Now the only CV power supply I have is my weldanpower 225 it will do 20volt at 200 amps not bad! When my current mig is lincoln weldpak 100hd (feel the power of 100amps! *sizzle* :laughing:)
So I trying to figure out how to best attach A to B.
I see a 12foot 400amp gun on ebay for $135 with a lincoln tail end. A
Anybody know a place online to get a roller for feeding lets say .035 I guess I can us it with .045 if I tighten it enough.
So anybody go any tips on either the LN-7 or the weldanpower?
Cant wait to get this set up, I need to burn together the mount for my wind turbine and I dont want to open a new can or rods. (ok I'm spoiled by GMAW)
Ok it seems from reading the manuals I need a K241 contactor kit....ya not buying that.
So made a little stub cable that I can attach the stinger to instead of having to take it to to bolt to the hermianl block. Then I wired in a section of a extension cord into the rear for 120volt now to just get a gun and some feed rolls.
Time to sleep.
   / Lincoln weldanpower with a LN-7? #4
Are you sure that feeder can take 120-volts? Some feeders will only take 24-volts. I don't really know just asking.
I have this same gun, but in the 15-foot version. I like the 15-foot gun but sometimes when running .023 wire they can be a problem.
Lincoln 200 amp Mig gun - 12' New on eBay!
   / Lincoln weldanpower with a LN-7? #6
That's a nice gun! I know the feeder can take 400 + amps, but you won't get that out of your power source. Are you sure you want to put up with such a heavy gun, or do you plan on getting / using a bigger power source at a latter date? Those 200-amp gun are really light.
Just bought that gun I was looking at, now to just find a a feed roller. And a can of lincoln red or gray :)
Got the gun and hooked it up now to give it some paint! Lincoln Gray or Red?
   / Lincoln weldanpower with a LN-7? #9
I think they're generally red, but it does seem like I've seen a few gray ones. How about pink?:laughing:
   / Lincoln weldanpower with a LN-7? #10
I vote red too..LOL...dont bastardize the Lincoln!..LOL
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2018 Freightliner...
TCM FD30T6T 5,600lb Straight Mast Diesel Forklift (A55973)
TCM FD30T6T...
