5105M joystick loader control
/ 5105M joystick loader control #1
montman
JD 5105M
have a new 5105M with 563 loader and is hard to fine tune the joystick because my arm cant rest on armrest - so all your arm weight is trying to control the joystick and get too many jerky loader movements. Anyone have same concern and what did do about it.
/ 5105M joystick loader control #2
Welcome to TBN, montman. I haven't experienced any problem with the loader joystick. Of course, the joystick handle and 3rd SCV toggle switch is the same as my other tractor. So maybe it's 'cause I'm just used to working the controls..
AKfish
/ 5105M joystick loader control #3
:welcome: montman
Sounds like you have an armrest but the control is too far away. That right?
If so, I'd find a way to bend the lever so it is within reach.
I think it will bend before it breaks.
A pic of your joystick would help for more suggestions.
/ 5105M joystick loader control #4
:welcome: montman
I'm pretty sure it looks like this:
AKfish
/ 5105M joystick loader control #5
Thanks AKfish
Considering the pic, I'd suggest bending or just adding an extension onto the armrest.
This is apparently a personal problem with arm wrist control that maybe others do not experience.
I don't experience it, so only can assume it is somewhat unique. Should be a workable solution tho.
Case 580L Backhoe Loader (A64047)
Case 580L Backhoe...
2" X 2" DIAMOND BAR W/ SHANKS (A63291)
2" X 2" DIAMOND...
Auger Drill Bit (A61572)
Auger Drill Bit...
2006 Peterbilt 387 Semi (A64047)
2006 Peterbilt 387...
SET OF UNVERFERTH LIFT ASSIST WHEELS & REACH ARMS (A63291)
SET OF UNVERFERTH...
2014 TEXAS PRIDE GOOSENECK (A63569)
2014 TEXAS PRIDE...
