Buying Advice New gc 2610
   / New gc 2610 #21
Dogscape, doing your own service is a great way to become familiar with your machine. Not too hard to do, and there are numerous posts on TBN about it.
About the most expensive part of it is the hydraulic fluid. Dealer prices for filters are right up there, too, but probably best to stick with them-- in fact, I'm not sure if anyone has found an exact replacement aftermarket transmission filter yet, but I could be wrong.
I've heard, too, that some dealers will include the first 50-hr service- ask.
Just find a place that will take your used oil & hydraulic fluid for recycling before you start.
   / New gc 2610 #22
I've had a MF 2610tlb since Dec 08. I love this tractor. Had a Kubota bx24 for 6 months before that. It was a piece of junk, started leaking hydro fluid with 10 hours on it, and it was NOT covered under warranty.
I have the 60" belly mower deck and mow several acres with it. It's very noisy compared to other tractors, such as the kubota. That said, I simply wear the proper ear protection.
It's pretty easy to put on and take off. Pick it up high and drop the pin on the rear wheels, turn them 90 degrees, and put the pin back in, under the support. The front wheels will turn 90 degress without doing this. That allows you to roll the deck out very easily while it's resting on it's wheels.
You can not lift the mower deck with the backhoe attached. Not that you'd normally be mowing with the backhoe attached anyway. But if you want to transport the whole thing at once, you'd better be sure to lock the mower in the highest position before switching the hoses.
The mower deck lifts on the left side before the right side, there is a fair amount of play in the shaft running side to side. and the hydo only lifts from one side. not a big issue but makes you think it's crooked when its just the lift mechanics.
The deck actually mows nicer than my John Deere X304, it doesn't scalp anywhere near as much.
I also have a hydo operated curtis snow plow bade that attaches to the loader arms. Lifts much higher that way than the standard blade that is frame attached. angles 30 deg each way too. so it's a big advantage over the factory setup thats frame mounted.
There are a few things they could make better on this tractor, but all-in-all it's a great setup and I would recommend it to anyone.
   / New gc 2610 #24
Chooglin, thank you VERY much for the information and pointer to the other thread! Here is upstate NY I currently have chains on all 4 tires, wheel weights, loaded tires, weight box and plow installed. When I get the mower deck and backhoe back out in about 4 months I'll be sure to review the connections. Sounds like the color coding on mine need to be reviewed and fixed. Just knowing it should work makes my day. Thanks again! :thumbsup:
   / New gc 2610 #25
No problem.............I hope you get it working properly.:thumbsup:
   / New gc 2610 #26
I leave the loader on all the time....this comes in handy when installing the mower. Get on flat ground with the bucket on the turf and roll the bucket like you are dumping something and lift the front end up. Then i just slide the mower across the dirt and under the belly. Thing mows like a raped ape too.
   / New gc 2610
Maybe...maybe delivery today! Dealer is arranging schedule for me now! fingers crossed. Very excited. Good weather to play with it. Cleaned out the garage...waiting for the call.
   / New gc 2610
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2017 FREIGHTLINER...
2020 MDB UT125KPLUS FLAIL MOWER (A51406)
2020 MDB...
UNUSED WOLVERINE TQH-26-02C CLASS 1 QUICK HITCH (A54757)
UNUSED WOLVERINE...
DITCH WITCH RT45 RIDE ON TRENCHER (A52705)
DITCH WITCH RT45...
UNUSED FUTURE 44" PIN ON RAKE (A54757)
UNUSED FUTURE 44"...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
