The Jake Rake
   / The Jake Rake
Thanks CTF! :thumbsup:
   / The Jake Rake
I like his concept. :thumbsup: He must have seen my rakes before. The only thing I can criticize is the wear parts are not replaceable however with the amount of use it will see i cant see anything seeing severe wear. :)
   / The Jake Rake #137
Just thought of you when I came across it.:D
   / The Jake Rake
When was your rake born ?
His vid was uploaded on July 23 2009
I don't recall the exact date however it was after the date of his posting. To be truthful I had never seen the driveway doctor before it was posted on here. I guess we think alike and I do wish the best for him. :)
   / The Jake Rake #140
Those appear to be railroad spikes (or something similar) on the drag portion. How are they held in place? I noticed in some of the earlier pics they seemed to be at different angles like they are just clamped between two pieces. Is that correct? Pics would probably be the easiest way to explain. Is it tough to get these for replacement or are they available locally?
bjepple
2011 Toyota Corolla (A55758)
2011 Toyota...
2012 Peterbilt 337 IMT 6025 14,000lb 5 Ton Crane Mechanics Truck (A55788)
2012 Peterbilt 337...
UNUSED JCT 72" HYD BRUSH CUTTER (A54757)
UNUSED JCT 72" HYD...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
UNUSED LANDHONOR LHR-LB9510 GAS LEAF BLOWER (A54757)
UNUSED LANDHONOR...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
