Watch Ya self serve gas
/ Watch Ya self serve gas #1
chopped
New England yankeee
This might seem like a fluke, But today I purchased gas at a local station which is a small chain componay who sells Gulf gas.Ive bought gas there before with no problems but a couple of times over the years I have caught them with the wrong price on the sign (on top of pump).And before the digital signs I also found that the street price and the pump price was different.
Also One statio has the grades from super to the regular with keys from right to left instead of the 'norm' of left to right.Caught myself once putting in super when I wanted regular.I always wondered if that was deliberate.
well today was a new adventure. I pumped as usual and clicked the regular button. And as I pumped I read the screen and it said puping super. I looked and the large button of grade was lit and it was regular.:confused2::confused2:
Again wonder .... I didt have the time to go inside as I had in the past . but in the past I never had much luck with the cashier to 'fix' it.
Anyways wondered if this was an ''odd' experience or not ..
/ Watch Ya self serve gas #2
Either they are dishonest or they just can't figure out how to run the business. In any event, I would avoid them from now on.
/ Watch Ya self serve gas #3
I have a friend that used to run an EXXON station, in those days the middle grade was the most popular with a few still needing premium. He told me that the station only had two tanks and that the middle and premium was the same.
Only the price on the pump was different.
/ Watch Ya self serve gas #4
It's true they only have two tanks, but the mid-grade is usually a blend of the two, done right at the pump. That's how they get the middle octane rating. All of that stuff, along with pump calibration, is heavily regulated by each state. Now, I'm sure a station could give away premium for a mid-grade price, but that wouldn't make sense financially...
/ Watch Ya self serve gas #5
It's against federal laws, the station could get a huge fine. If there doing this what else are they "not" doing. Like cleaning out there water separation filters. There should be a transportation sticker on the pump with a phone number.
/ Watch Ya self serve gas #6
We don't have buttons here in the UK.
There is a switch that detects what pump has been lifted and selects that mode.
/ Watch Ya self serve gas #7
The only thing you said here that I've encountered is street sign price and the pump price being different. Never had any of that other stuff happen, so it would definitely be an "odd" experience for me.
/ Watch Ya self serve gas #8
I'll keep punching the button with a smile on my face as long as I don't have to pay as much as you do for fuel in the UK.:D
I'm at that point in life that I have to remind myself to put diesel into my truck instead of the gasoline nozzle. One day, I kept punching the button several times and was ready to go see the attendant when I noticed I had put the gasoline nozzle into my truck and was punching the diesel button.:confused2: I quickly scanned to see that nobody had seen my dumb mistake and switched nozzles.:eek:
/ Watch Ya self serve gas #9
There was a Dateline story on this a couple of years ago. Seemed "defrauding" fuel customers was pretty common in the N.East . The two biggest things where 1. selling a lower grade fuel as higher grade, and 2. Metering out less fuel than the pump read.
They rode around with the inspectors that had an exact 10gal hidden tank (New Jersey I think) since they said the modern technology allow some unscrupulous station owners to change it with a "switch" They said they where so short of inspectors nation wide that it was impossible to to check every station.
2 things that stuck out in the story to my wife and I was, the violators they did show didn't speak English well and the other was the inspection stickers on the pump where good "on the day" they where tested.
/ Watch Ya self serve gas #10
This got me thinking. Does anyone else remember the old Sunoco pumps that allowed you to dial in about 8 different grades of gasoline by moving a selector on the pump? I assume they were just changing the blend from two tanks.
/ Watch Ya self serve gas #11
I bought gas from one of the old glass pumps...
Left little doubt as to the clarity and volume if you bought 10 gallons...
Try to put more than 10 gallons and the excess went back to the underground tank...
/ Watch Ya self serve gas #12
I don't know how all the states do it, but when Dad had a Texaco service station in Oklahoma and then a Mobil station in Texas, both states inspected the same way. You never knew when the state inspector would show up and they had a special kind of 5 gallon can that had a thin glass cylinder at the top, so he'd pump 5 gallons according to the pump, then look at that glass to tell exactly how much he had pumped, then he'd dump it back into our underground tank, except that he'd put maybe a half cup or less in a little bottle that he'd label. He'd do that for the regular gas and then for the ethyl pump. The little bottles were to check in the lab to be sure we had regular in the regular pump and ethyl in the ethyl pump. In our case, we never had a problem, and certainly didn't mind the state checking us.
/ Watch Ya self serve gas #13
Yep, the low grade was 190 and the top grade was 260. You could mix any grade in between in increments of 10. As I remember, the 260 had so much lead in it that it had a bluish-green shade. A buddy of mine had a Sunoco station in Virginia Beach, Va.
/ Watch Ya self serve gas #14
This past December was in central Mich. the fuel man had been on and was reading 3 miles to empty so pulled into a Mobile service sta. Next to our truck was a state measurment man and while filling talked to him. He showed the past record of the pump and present fill of gas was accurite. also took sample for later check of quality. Told us the cost of selling bad gas was to great for any service sta. to try .
He did admit some times there is water in gas but pumps have filters to catch only when so much it overides the filter then pump is very slow.
15 years ago took a 5 gal gas can with fuel in can maybe a gal. and at service sta was filling and noticed the pump was over 8 gal. of fuel stoped the pump talked to attendant He acted like I had put fuel in truck first. wouldn't do anything. Called the state group that does this checking about the problem. They asked if I could wait 10 minutes for a man from there group to stop by and not allow anyone to use pump. said O'k. In less time the measurment truck stopped and pumped into 5 gal container and came up 8 also. the next day the station was closed.
So maybe this group does a good job.
ken
Ok I just typed a nice. letter to the head company and explained. I wasnt bad mouthing them Just stated what had happened.Of cource when I clicked to sumit it didnt work But I had set the words into copy and then resent it. So Ill see how they react..
/ Watch Ya self serve gas #16
i know in florida there are dpt of ag stamps on the pumps.. if something weird is goin on.. you can call and report them
does your state have the same?
