270 backhoe
/ 270 backhoe #1
wooden
1992/318 & 2010/2720 deere
Re posting a question on the 270 backhoe . I had read they would be released in the fall so I am wondering if anyone was able to buy one as yet and how is it's performance?
Seems as advertised by JD, you no longer need to remove the lifting brackets for the MMM with this unit and so it would be the perfect fit for my 2720.
/ 270 backhoe #2
I have not heard of them being officially for sale yet...just a lot of talk and a quick mention in the brochure.
/ 270 backhoe #3
I've been following developments on this product and made the following post in August.
"Heard an update on the JD 270 hoe from a friend this morning saying its release is 'going to be delayed again'. Seems that JD hasn't gotten everything working the way they want it and are taking the time to resolve the problems before it goes into full-scale production. The 46 hoes were almost completely depleted and JD has evidently re-started production of them, so 46s are again available. Of course, this likely means that, once JD is finished with the 270 and has it the way they'd like, we're going to have to wait until all the new 46s are sold before the 270 will be available for sale."
While I've continued to keep my ear to the ground and ask questions of friends, dealers, and people I know on the inside, I've heard nothing new since that time.
/ 270 backhoe
Thanks for the reply. I am going to wait on this one as I can't see having to take apart the MMM brackets to fit a 46. I also understand that the 270 will cut 7 feet. another plus!!
Thanks again
/ 270 backhoe #5
You're welcome! And I agree with you. The 270 digs deeper and doesn't require the removal of the mower and 3 pth arms, though I haven't been able to imagine how the latter is achieved without conflicting with something. Perhaps that's why this release is taking so long :D
/ 270 backhoe
Funny thing is, When I first started looking to up grade, I looked at the JD site and saw a short vedio with a lady backing up to a backhoe , picking it up and driving off. This was a selling point, so I got the biggest of the small tractors, 2720 and figured I would be set from there. My dealer never mentioned anything about what was involved with attatching a backhoe. Thanks to this site I learned the hard way. Lessons learned.
PS . she never left the seat except to connect the hoses.
/ 270 backhoe #7
I will be buying a 270 BH for sure. Hope it attaches via quick hitch.
/ 270 backhoe #8
I wish I'd seen that video. Nevertheless, the normal way to connect a hoe is to back up tje tracor to the hoe, get off to connect the hydraulic lines, then remount to use the hoe's hydraulics to maneuver the hoe onto its mounting pins or stems. Usually, you have to dismount one more time to insert pins on each side to secure the hoe to the tractor.
/ 270 backhoe #9
Well, I'm sorry to say that a backhoe won't connect via a quick hitch. A backhoe puts a lot of strain on a machine, and except for the bigger machines, those that connected to the 3pt hitch often broke things or tore them apart. You want a hoe to connect to the frame of the machine itself because of the large forces that are applied as we tug at stumps and large boulders to loosen them. On the bigger machines, the 3 pt hitches are heavier duty and a hoe's forces can better be handled.
/ 270 backhoe #10
In reality, I would hope the 270 uses some new brackets on the 2000 series tractors that leverage the existing mounting holes in the heavy frame inside the rear tires. (I actually would not expect a quick hitch enabled 270, except for moving it around). That said however, I owned an old Bradley back hoe 3ph mounted on a Ford 1710 tractor which dug up everything I could throw at it, and it worked well. So, a 3 ph mount (not quick hitch) for a 2000 series CUT does make sense. S.
/ 270 backhoe
From the promo photos I saw on the JD site It mounts to the frame of the tractor on its own brackets that seem to be built on . No removal of the 3pt hitch bars needed. Big thing is I won't have to remove the MMM brackets as you would have to with the 46. That's my selling point.
/ 270 backhoe #12
Any updates on status of the 270? Last I heard was now spring '12.
/ 270 backhoe #14
Given that its release has been re-scheduled multiple times, I'd add on an extra few months if you're planning work based upon its release. If it does come out on this latest schedule, we'll be delightfully surprised.
/ 270 backhoe #15
With all the delays I am not sure I want to be one of the first owners...
/ 270 backhoe #16
You make a valid point. The fact they've misread when the product would be ready so many times certainly implies they could get it wrong another time or two.
/ 270 backhoe #17
My dealer now says June of 2012 -- I have one on order, looks like its going to be awhile yet.
/ 270 backhoe #18
Are you kidding me? Another delay? While I understand how a delay or two can creep in and the manufacturer should want to get the product right before it goes out the door, I'd fire the product manager on this one for getting the date wrong so many times. He should have either allocated enough time to deal with the problems once he knew the product missed the first date, or bring in extra manpower to meet a commitment fate. Unbelievable!
/ 270 backhoe #19
If they had to do another production run of the 46BH then they are going to wait until they sell them all, otherwise they never will be able to sell them. Unfortunately a lot of people know about the 270BH so they are holding there purchase slowing down the introduction even more. It sucks.
/ 270 backhoe #20
That's what happened to me. I want the deeper depth of this hoe, the ability to keep the 3PH on, and especially, the thumb. But if they're not going to deliver on time or within some reasonable time due to a legitimate problem discovered later, don't keep setting and cancelling release dates. That just shows incompetence in managing and decision making, lowers credibility, frustrates the customers, and sends some "would be" customers to competitors -- not smart!
208316 (A58375)
208316 (A58375)
Frontier RC2060 Rotary Cutter (A64047)
Frontier RC2060...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
2015 Ford F750 Service Crane Truck (A62613)
2015 Ford F750...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
