Waxing your tractor !
/ Waxing your tractor ! #21
Mine gets a thorough spraying with Fluid Film each Spring and Fall and looks as good as new despite all the winter salt on the roads.
/ Waxing your tractor ! #22
Yes I wax mine. I also armor all the tires and rubber mat. Nothing like a spotless Deere!
/ Waxing your tractor ! #23
My dad has a 1970s era Kubota B7100 - actually he thought he got it in 1974, but tractordata says they weren't made until 1976. Either way, no one around had seen one at the time, and he got one of the first two that the dealer received. He has washed and waxed it at least once each year. That was all it took to keep it looking practically new. No one can believe how old it is today. I pointed out however that my 4005 has a lot more surface to wax than his Kubota and I can't say I look forward to it.
/ Waxing your tractor ! #27
Waxing is part of maintenance. I use my tractor all year round for many chores and when it has wax on paint is much easier to keep tractor clean.
It is a tool but also an investment.
hay.. i use 303 also. it does seem to work nice
Been using it for over a decade on my motor home rubber roof, keeps it clean and protects it from the sun. Also works great on leather. Buy it online by te gallon it lasts me about 3 years. Good stuff !
/ Waxing your tractor ! #30
Just a comment about the tires and Armor All... There's a lot written on the web about the petroleum based tire treatments. Basically, they interfere with the additive put into the rubber to resist UV damage from sunlight. I recently looked at a 2-year old trailer that's been sitting idle mostly. The four tires on the axles had tire dressing applied often while the spare did not. The spare was in fine shape. The other four had checks and crack all through the sidewalls. Water based tired dressings do not create this problem. YMMV.
/ Waxing your tractor ! #31
Your better off using silicone spray. Work good on tires an fishing boots, keep them from dry rotting.
But it doesn't have the UVB and UVA protection quality. The reason I started using 303 is because of my motor home tires had cracked on a 3 year old unit. Cost me almost 4 grand to replace them. After tons of research I found that ozone and sun is the culprit and protecting the rubber is key, been using 303 ever sense. It's a laboratory proven product. Check out there web site, there is items over 50 years old some treated some not and you can see the differnce.
/ Waxing your tractor ! #33
I 100% agree, Armor All is NOT recommended on tires or any other soft materials like the dash of many cars.
/ Waxing your tractor ! #34
Jamming could you be more specific on which 303 product you are using?
I checked out their web site, but I wasn't sure which product.
Thanks
Turns tires brown and damages vinyl, but it's cheap and they sells tons of it I'm sure.
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
JLG Scissor Lift (A64047)
JLG Scissor Lift...
2015 ISUZU NPR 4X2 16FT BOX TRUCK (A59912)
2015 ISUZU NPR 4X2...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
Spray King Pull Type Sprayer (A63116)
Spray King Pull...
Fellabuncher Dangle head, PARTS ONLY (A62679)
Fellabuncher...
