New Goodies installed on the L3200
   / New Goodies installed on the L3200 #1
kubotacres
Gold Member
Louisiana
Kubota L3560 HST
Well since my lift jerk has been fixed,I've actually felt like adding my goodies to my L3200. Added a new Front Guard with weights (weights i made), Stabilizer Kit for the 3pt hitch, and installed a Work light. I included pics of them below... About to put it to work finishing my barn.
   / New Goodies installed on the L3200 #2
Looking good :thumbsup:
   / New Goodies installed on the L3200 #3
Looks really good. You must have decided it is a keeper.
How did you make that nice weight set and how much weight is there?
The weights make up about 60lbs. I have room for a additional 20lbs if needed. However with the weights and the guard combined it's just right to keep my front wheels planted on the ground. Even seems to ride better considering the front doesn't "bounce" around while driving.
   / New Goodies installed on the L3200 #5
Nice work. What was the cost for the stabilizers?
$175 shipped. maybe high for some, but def worth it to me. I hated those turnbuckles.
   / New Goodies installed on the L3200 #7
Can you post some up close pics of the stabilizer ends (where it attaches to the tractor as well as the lift arm)? Also, what is its length range? I'm thinking they may work on my Ford 1920 as that currently has turn buckles as well and they are annoying.
Here is a closer pic of them. I dont know the actual length, but I'll check it out.
   / New Goodies installed on the L3200 #10
Thank you. If you could can you measure how wide the flange is on your tractor that the stabilizer attaches to? It looks like the same size as the 1920.
2007 International 4300 DT466 Refer Truck (A47384)
2007 International...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
Swamp Buggy (A49346)
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
2017 Dodge Grand Caravan (A50324)
2017 Dodge Grand...
