eBay/Craigslist Forks price check
/ Forks price check #1
ericher69
Ontario Canada
2008 Kubota b2920
42" for $140
48" for $160
Good price used?
Also Which would be better suited to kubota b2920
Thanks
/ Forks price check #2
That appears to be a good price. Are they Kubota forks, or an aftermarket brand? Do you know the weight and capacity of each of them?
/ Forks price check
Do not know any more info
I will try and email seller
Thanks
/ Forks price check #4
I had a B2920 (especially if these are clamp on forks and at that price I assume they are) get the shorter 42".
With another tractor I had clamp on forks and didn't like them. When I bought the 2920 I got the Kubota quick attach with a set of aftermarket forks. The difference between clamp on and a set of frame forks, IMO, is not even close. But you do pay for the difference, I think in the long run they are worth it and they put less stress on your loader frame and bucket compared to clamp on style.
/ Forks price check
They came of a crown forklift
4000lb capacity
/ Forks price check #6
I've always marveled at how forks don't bend at the corner, even over time, given the leverage...
/ Forks price check #7
4000lb capacity
How do you propose to attach them to your B2920?
I agree with Tompet. Clamp ons are not the way to go. There are many threads and many reasons (some posted by me) for this sentiment. The only reason that I ever ordered a set of Payne's to begin with was because they would be delivered quickly and I absolutely had to have something to unload a bundled up building that was being delivered to the house. Never again will I deal with those things. Especially since I now have SSQA and Bradco forks.
/ Forks price check #8
/ Forks price check
What do you mean by clamp on's?
I thought the all attached to some type of quick adapter?
/ Forks price check #10
I purchased a really nice set of clamp on forks from these folks...
I cut two pieces of 1/2" steel to use as a bucket support when screwing down the locks...
I have had very good success with these and would highly recommend them for those folk looking for a lower cost alternative or those that have a pin on bucket...
Clamp on Loader Bucket Skid Tractor Pallet Fork chain | eBay
/ Forks price check #11
The forks you are looking at are probably skid steer standard, and will not fit the B2920 without a very heavy adapter. Check that out first.
The B tractors have low capacity and adding weight (forks weigh alot) to the loader and extending it out will reduce it too much.
The best setup for these small tractors is the Kubota factory quick attach with their own fork setup or from ConstructionAttachments.
/ Forks price check #12
if they are just crown forklift forks, you need to have some type of carriage to attach them them to your FEL
/ Forks price check #13
No matter how good you can clamp that type of fork onto your bucket, you are lowering the capacity you can lift by extending the center line of the load from the tractor
Best fork arrangement for any serious load is pin attach or better yet qa attachment forks
207283 (A52708)
207283 (A52708)
2017 CATERPILLAR 242D SKID STEER (A62129)
2017 CATERPILLAR...
New/Unused Wolverine 72in Quick Attach Tiller (A61166)
New/Unused...
2010 Deere 318D (A60462)
2010 Deere 318D...
300 Gallon Sprayer (A62177)
300 Gallon Sprayer...
Misc. Items (A62177)
