How useful is a snow blade - front or back?
   / How useful is a snow blade - front or back? #21
Usefullness of snow blades is pretty dependant on the size of the machine they are attached to.:thumbsup:
I would have to disagree with you there. The 60" power angle front blade on the BX2660 with a cab is more useful and will push more snow in less time than the 72" manual angle backblade on the open station L3830.
Aaron Z
   / How useful is a snow blade - front or back? #22
Put the back blade on a bigger machine.:thumbsup:
   / How useful is a snow blade - front or back? #23
How about both? It's fast and gives me a lot of options for pulling or pushing and with the quick attach I can swap out the homemade front blade for a bucket to pile up snow. I use chains front and rear after things ice up - I go easy and no problems so far.:thumbsup:
   / How useful is a snow blade - front or back? #24
My near future project is to use a landscape rake such as this one:
http://orders.leinbachs.com/cart/ma...cts_id=28&zenid=mava9sl4ihkmercbmiq50sdi16and and attach to it a piece of conveyor belt about 7 ft long and 24-30" wide. Since the belt will be bent to the curvature of the tines it will be stiff enough to be wider than the rake itself. Beside snow clean up I will also use it to scrape mud from our concrete in front of the garage or the shop.
Thanks guys, more ideas. I especially like the pics that I can copy features off.
What would be the maximum/minimum useful height of a 6 or 7 foot blade for my JD 2320(24 HP) - any difference pull or push?
Jack
   / How useful is a snow blade - front or back? #26
Jack
My 6 foot blade is 14 inches high.
3 Point Hitches can't take as much force pushing as they can pulling. A 3PH snow blower doesn't really have that much force on it when it's pushing because the snow doesn't have a chance to build up. But it does with a rear blade, so it's better to pull a rear blade than push it.
   / How useful is a snow blade - front or back? #27
VERY TRUE!!! There have been a couple TBNers who broke lower link arms pushing with the rear blade.
   / How useful is a snow blade - front or back? #28
Remember, a truck type plow blade has a trip mechanism to prevent a rouge stump, manhole cover, etc from taking the truck from 20mph to 0mph in 2"
A backblade or a loader bucket have no such mechanisms, so you need to watch where you are going and know what is under the snow or you could break things in a hurry.
Aaron Z
I'm still pondering the blade issue and a strange idea hit me as I was viewing the JD 200CX loader (prompted by PILOON's reference to a blade tied back to the rear axle via long arms). I guess you'd call this a bulldozer format.
The 200CX loader has a tube (maybe 2 1/2" D) that provides cross bracing. The open ends are a potential lifting point for stubs that could be inserted into these tubes (the height function for a blade). The main mounts of the loader that tie to the frame are a potential hinge point for straight arms running on the outside of the front wheels of the tractor to a blade (bucket would be removed). These straight arms that tie to the blade could be extendable to allow some angle adjustment of the blade, provided the blade/arm mounts swivel and the blade is lifted via a center pivot point. Furthermore, the unused bucket mount points could possibly be configured via some mechanical contraption to provide another function - perhaps tilt to the blade?? Should be possible to make this easily removable.
Two objectives are behind this idea - getting the blade forces off the loader proper and onto the frame and bringing the blade closer to the front of the tractor. Am I overlooking some impossible challenges here or is there potential ?! :confused:
   / How useful is a snow blade - front or back? #30
The BX2660 is the best machine unless you need to push banks, it doesn't have quite enough weight to push back hard banks of snow.
Here is my BX1500 with the same blade.
Not only will it move snow quite well it is also great for pushing dirt gravel sand etc .
Try that with your snow blower.
   / How useful is a snow blade - front or back? #31
:2cents:My two cents. I have 50" and 60" blowers for big snow falls(none this year). I use a 84" Back blade and loader for smaller (6" or less) because I find it so much quicker. I would not put the blade on the front for the same reason I did not go with a front mount blower. The FEL is way too useful of a tool to leave it in the shed.:thumbsup:.IMO
Have patience when it comes to finding a used blade. I'm from the winnipeg area so I know your over woes about candian pricing(My new toy a Z465 is coming from Arkansa). I found a heavy duty but old John deere 84" back blade for $200 and on another deal was a KK scoop with a 84" kk back blade packaged for $260.:D
Deals come up, check auctions, kijiji, usededmonton.com. The hunt can be almost as enjoyable as using or making a new implement.:laughing:
One thing nobody mentioned was the use of a box blade for snow removal. It works good if the snow is light enough and the drive is short enough. The advantage is your not leaving windrows on each side of your driveway. You'll pay for doing that around here the next time it snows or blows.:ashamed:
Thanks for the latest 2 cents worth - it is way more valuable than that. I am in the process of constructing a rear blade. That choice allowed me to justify a Hypertherm Powermax 45 plasma cutter to my wife :laughing: - wow - is all I can say about that.
JoeL4330 sent me a picture of his Landpride with all the bells and whistles and once I saw that, I was hard pressed to be satisfied with the most basic blade. That's probably a mistake on my part but it's in my nature.
So here's what I'm doing. I'm kind of following the Landpride format with the option of adding hydraulics later. I have fastened two 7 foot x 3/4" thick blades (cut back to 6'-3" for my JD 2320, about 14" tall) together using 5/8" thick 23" diameter pipe cut appropriately as backing. Welded into this backing is a rectangular channel that allows the main rectangular vertical support tube to pivot, thus providing about 8 degrees of tilt either way. The blade can be inverted top to bottom to give me the choice of a very sharp edge or the flat worn edge. I have rightly or wrongly assumed that I can benefit from floating tilt with skids at either end of the blade and a guage wheel in the middle. It's too late to turn back on the tilt so we'll see (of course I can always just lock it at level - 0 degrees). All this is going to be over build and heavy but I have been assured that heavy is good.
I also am constructing the main member that goes from the iMatch out to the blade so it can swing to offset the blade. To do this I will be creating taller pivot points for rigidity. The blade itself will also angle via a pivot point. The square tubing I am using is 3x3x1/4 beefed up when necessary.
After typing here for a few minutes I think it makes more sense to include the pic of Joe's Landpride because it, in scaled down form is my guide. And my daughter has just taken 3 pics of this grungy looking project (my camera is fried). Two are of the blade proper and one is the piece that attaches to my iMatch 3-point.
I am not a mechanical engineer, machinist of mechanic so can't claim what I am doing is particularly great but those of you that build things will appreciate that there is a small sense of pride involved (very humble pride of course :eek:) Caviat: 90+ % scrap material, including 23" D. heavy pipe pulled from my fire pit after 25 years of burning, grader blades found in county ditch etc.
Jack
   / How useful is a snow blade - front or back? #33
Thats Not over built. Its built to spec for land mine removal for use in Iraq!!!:p
   / How useful is a snow blade - front or back? #34
Looks like you're going to make yourself a fine tool there :) And congrats on the plasma-cutter: one has been on my "work out how to justify it" list for a long time :eek:
I now own a snowblower because I was unable to follow the excellent advice I have quoted. Our driveway offers little choice when it comes to leaving windrows, and the results are inevitable.
Before: (I was REALLY happy with this job- I thought I'd done a fine bit of work)
The same driveway (looking the other way) a few days later.
Moral of the story... Get that snow as far away from your driveway as possible!!
All I can say is wow!!! I think I'd be praying to go to heaven real quick, where presumably there is no snow. :) Is that Sweden? Of course, I had some idea what wind can do with fresh snow but here in Alberta where I am, that sort of scenario is uncommon. I certainly admire anyone with the initiative to tackle that. Wonder what folks in Arizona think of snow blade talk?! Ah, but we have winter sports :)
So my blade is overbuilt - guess I'll need a new tractor :tractor: to accomodate it - have to try that on my wife. Then I'll need to create a long and winding driveway to justify it all.
Jack
   / How useful is a snow blade - front or back? #36
Yup... it's the south of Sweden - not usually that snowy, but last year we had a winter that had snow on the ground for a solid 4 months and temperatures that hit -25C (around -15F)
It's all the wind. Look closely in a couple of photos and you can see nearly bare grass in the field to the right.
Like in this one:
Have a look at all the photos if you fancy :) https://picasaweb.google.com/sensiblenick/Winter20102011# (including my backblade with wheels to ensure I don't mess up the potentially soft driveway, and a nice wing on it: makes pretty edges. :)
Nick, I looked at the blade with the dual gauge wheels. They are not set up as "casters" but look like they do the trick nicely. I imagine you can't back up while they are down but that probably doesn't matter since you can raise the blade. I am just in the process of mounting the two skids on the outer ends of my blade and now I'm wondering if wheels wouldn't be better. For dirt or gravel they would be for sure. I had originally thought of one wheel in the center only. Do you use the wheels in snow?
Any comments??
Jack
   / How useful is a snow blade - front or back? #38
This backblade was the cheapest I could get. It is actually designed with Cat2 3-points in mind, and the points are a little too far apart and high for my little tractor. Next time I have nothing to do (ha!) I might hack the frame about a little. On top of that, the fixing of the wheels is really sloppy. I hate it.
(My) Rear wheels are great once you have them set up correctly but I have half a plan to make them hydraulicly retractable: It's hard to lift it and the wheels high enough to stop the wheels dragging. and changing the hydraulic toplink to help lift high enough messes with the perfect setting I'd just managed to attain. :eek:
I do use the wheels in the snow just to get things started and attain a nice smooth hard snowy surface, and then I take them off.
I can't reverse (blade down) with my wheels because - as you point out, they only swing though 180 degrees. (might have to fix that when I get all hydraulic on it :D)
If I were in the situation you are in, I'd be playing with one castoring wheel.
I think the system you're taking inspiration from is by far the nicest way of going. the notated picture had me drooling and wishing for more remotes... you're starting with a clean slate, so why not make the best tool you can? :)
Worth noting though: I would not be able to do this (see below) if I were using skid-plates/shoes. I like to rough the stuff up, smooth it out, and let the rain pack it down. Skid-shoes would leave big ruts.
Nick, Thanks for that - it seems "sensible" and it gives me more confidence going forward. Due to health issues, my progress is slow but determined. Because I don't want to have to revisit this in the future I'd like to get it right the first time.
Yes, isn't Joe's blade a dandy!!
My problem is obviously that in spite of having some "common sense", I've never done anything using a 3-point hitch with dirt or snow. Since posting the pics you viewed, I have completed two mounting plates that can be utilized to place either skids or wheels, and based on your comments, I will mount the skids I bought, but plan on removing them and placing wheels in the summer. I will drill and tap holes in the plates for the appropriate bolt-on mechanism. Perhaps the pair of wheels could be smaller ones with a larger caster in the center that is potentially hydraulic for adjustment on the go. On the other hand maybe three is ridiculous??
Any other readers have a sense of where this should go?
Jack
   / How useful is a snow blade - front or back? #40
Have a look at all the photos if you fancy.../QUOTE]
Enjoyed your photos -- thanks for sharing!
I'm always amused at my surprise to find that your surroundings look no different than our surroundings here in the states. I half expected to see the Aurora Borealis hanging in your background sky while you were plowing snow at night.
Also, kudos on the chain sets you made. We often compliment the builders on this site for the nifty attachments they build that look as if they're commercially made. Your chain design looks even better than the chain sets I see around here.
Deere 410L (A53317)
Deere 410L (A53317)
2020 SAVANA 3500 16FT BOX TRUCK (A59905)
2020 SAVANA 3500...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2021 Deere 333G (A53317)
2021 Deere 333G...
iDrive TDS-2010H...
Margaritaville Miniature Decorative Truck (A59231)
Margaritaville...
