2003 Excursion - IF you're looking
/ 2003 Excursion - IF you're looking #1
Gem99ultra
Elite Member
Mid-Georgia
Kubota L3400HST
Seems to be a lot of guys looking for Excursions...? If so, there's a pretty nice one on Iron Planet, current bid $4750. Here's the ad:
Four Door, A/C w/Dual Zone Climate Control, Ford Triton 6.8L V10 FI SOHC Gasoline Engine, Automatic Transmission, Multi Function Steering Wheel, Heated Drivers Seat, Heated Passenger Seat, Cruise Control, Power Windows,
Power Door Locks, Keyless Entry, Power Mirrors, CD Player, Rear Parking Aid Sensors, Alloy Wheels, Running Boards, Fog Lights, Hitch Receiver, Rear converted to Entertainment Area
Highest bid US $4,500
Bid Increment: US $250
# of Bids: 1
US $
Next bid must be at least US $4,750
Reserve not met
Bidding closes in: 3 days, 9 hours
ps I have NO affiliation with Iron Planet.
/ 2003 Excursion - IF you're looking #2
I'd love to have an 02 Excursion with the 7.3l Powerstroke diesel. :thumbsup:
/ 2003 Excursion - IF you're looking #3
Great truck. I bought a 2000 PowerStroke 4x4 - ordered it the first week the dealer was taking orders. I pulled a 32' trailer like it was on rails. ...miss that truck!
/ 2003 Excursion - IF you're looking #8
Duffster said:
Thanks for reminding him.
Yeah, it's tough keeping up with all the changes since they can't make one good dependable engine...
/ 2003 Excursion - IF you're looking #9
Insert snarky comment about Dodge here.
You could always buy the Dodge equivalent to an Excursion.....oh that's right, there isn't one.
If it weren't for Cummins, there probably wouldn't be any Dodge trucks to buy.
OK, I'm done capping on Dodge.
/ 2003 Excursion - IF you're looking #10
You can "cap" on Dodge all you want. If the Excursion was a good seller, I'm sure you would have seen a Chrysler version but they were busy creating the cross-over class (Pacifica) which is the largest selling class now.
The Cummins is just one of the great engines found in a Dodge truck. Don't forget the solid 318 V8, torque filled 360 V8, and the greatest normally aspirated gas engine ever put in a truck, HEMI 5.7.
But, to each his own...
/ 2003 Excursion - IF you're looking #11
My Cummins will still be chugging along when the truck rots around it. :thumbsup:
/ 2003 Excursion - IF you're looking #12
greatest normally aspirated gas engine ever put in a truck, HEMI 5.7.???
Greatest for what????:laughing::laughing:
/ 2003 Excursion - IF you're looking #13
You do realize that "HEMI" is marketing hype don't you? Maybe in the '50s the "Hemi" was new and different, but not so much anymore. I think everyone uses hemi heads on their engines these days.
You hardly ever hear "I bought a Dodge truck". It's "I bought a Cummins".
Chrysler should erect a statue of the guy who made the agreement with Cummins to provide engines to them.
All the companies make good engines, if the feds would leave the car companies alone, they wouldn't have to change/update engines every other year.
/ 2003 Excursion - IF you're looking #14
Call it hype if you want but the Dodge HEMI has a head design much closer to a hemispherical than any other manufacturer designs. Obviously no ones using the"pent roof" head design anymore. The hemi design is not very efficient hence the need for dual spark plugs but it's the reason for good low end torque and high rpm power.
Also, only the poorly designed engines need to be redesigned every couple of years. The HEMI was released in 03, added Multi Displacement System in 2006 and mostly unchanged since. Also, the Toyota and Nissan V8's have had very little changes as well...
/ 2003 Excursion - IF you're looking #15
Good for screaming while towing. Been there done that.
Chris
/ 2003 Excursion - IF you're looking #16
If memory serves me correctly the Chrysler Hemi's of the 50's/60's were chosen as they would allow higher compression ratios as compared to the wedge type heads.
Don't know if that still holds true for today.:)
/ 2003 Excursion - IF you're looking #17
Chris
Ha ha! More proof you never owned one. And this is coming from a guy who thinks that anemic Ford 5.4l and Nissan's 5200 rpm 316hp screamer are great towing engines! Too funny!
/ 2003 Excursion - IF you're looking #20
I c, as some point they did, or part of them. Thanks for the education.
Unverferth Seed Runner 3755 (A64119)
Unverferth Seed...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
2005 International 4300 Rollback (A62613)
2005 International...
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
(APPROX. 21) 4X6X16 ROUGH SAWN PINE (A64276)
(APPROX. 21)...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
