Loader Putting A Loader On A 4000
   / Putting A Loader On A 4000 #1
jtcweb
Member
S.E. Michigan
Ford 2N, Ford 4000 and DR Field & Brush Mower
Hello,
I have a '64 4000 row crop tractor. A friend of mine has a 2000 (regular non row crop) that he took a loader off of. Is there any chance of putting the loader on my 4000? I know I need to go out and get the model number of the loader, but wanted to ask first. Also what should I look for when looking at this loader? I have no experience with loaders, but have owned a 9N and now the 4000 for many years and used them mainly for mowing and grading.
Thanks
Jerry
   / Putting A Loader On A 4000 #2
Hello,
Thanks
Jerry
You will have to do alot of modifications to the front mount of the loader. You need to find a 1arm bandit style loader and also pm soundguy he must have 10 of these year model tractor in a configurations he should know what your needing
   / Putting A Loader On A 4000 #3
ditto what whodat said.
if you are using a loader modle that uses the ag front bolster.. especially a pin / hanger style, then you will need significant fabrication.
mind you.. torch and welder work makes lots of stuff fit lots of other stuff.
if it was a 1-arm laoder, all you would need different is a different front hanger bracket, and it can be torched out easilly.
what loader modle is it? it's possible there are factory brackets available for it to mount to a rowcrop... mind you.. these may be hard to find.. however after looking at a diagram in a parts manual, you might be able to fab them up..
I'm going to go out and look at it sometime this week and I'll get the model number.
2016 Dodge Caravan Van (A53424)
2016 Dodge Caravan...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2018 UTILITY VS2RA...
2016 Ram 1500 Crew Cab Pickup Truck (A55852)
2016 Ram 1500 Crew...
2022 Wacker Neuson LTV6 Towable Light Tower (A55851)
2022 Wacker Neuson...
