Gary Fowler
Super Star Member
- Joined
- Jun 23, 2008
- Messages
- 11,998
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
I Had some gravel being delivered for my driveway and brother in law wanted some shale for his road so the driver delivered him 14 yards in a tandem wheel dump truck that promptly got sunk to the axles on one side. B-I-L asked if I could come over and pull out the truck. When I got there, the truck was leaning downhill and high side tires were coming off the ground. I tried to pull him out with chain to front bumper of truck and chained to my drawbar. After several tries and tractor jumping up and down which is hard on the drive train, I stopped and decided that maybe I could push him from the rear but couldnt do that either. Finally positioned my FEL against his dump bed to dump his load That is when I noticed my drawbar hanging out the back at an angle. When I got off to examine it the cast steel bracket thru which the drawbar pin goes into the front of the drawbar had sheared the back half off and I found everything but the pin which was amazing in itself. I found both broken half circle back pieces of the bolt bracket and even the hairpin clip but never did find the pin. I guess they make the bracket weak so it breaks rather than break off a chunk of the tractor. Finally got him out after we got the 30,000 # of rock off. I put the FEL under the back low corner of his bed and lifted and pushed a the same time. It came right out. After breaking the bracket we finally did it the way we should have but was a little afraid to raise the bed since it was leaning so much. Will try to take a couple of photos of the broken bracket for later post.
