New Grand L5740
/ New Grand L5740 #41
Thanks All. The shop is 60'x120'. Got 110 gal. of RimGuard coming for tire ballast. Still working on other pix. Thinkin bout a video of maybe.
I need to do this for my tractors, (rimguard) but haven't had the chance to check around too much yet. Are you having someone deliver it, and do it yourself....? or..is a truck coming to your house to do it? I'm curious about delivery choices....
thanks!
/ New Grand L5740
thanks!
They come to my shop and fill the tires. Generally takes about 45 min to an hour. I don't have to do a thing but write a check.:laughing: I tried filling my own on my BX 2660. It was a big pain and took for ever. You have to hand pump the fluid (on your own) and then burp the air out periodically. I bet it took me 3 hours for 10 gal. per tire vs. 55 gal. per tire. I'm glad to just sit back and write a check on this one.
/ New Grand L5740 #43
Awesome...thanks!
I imagine it's a pretty heavy truck that delivers it.....might be an issue with my concreete driveway....:laughing:
Thanks for the info.
/ New Grand L5740
Awesome...thanks!
They come out in a F-450 service truck. So as long as your drive is at least 4" thick, as it should be, you'll be fine. My shop is 6" thick, but I have 80,000 GVW trucks driving around.
/ New Grand L5740 #46
I just got my l5740 a couple of weeks ago. With the factory radio. And the speakers are awful. So I will be looking to replace them. I will also be putting in a standup rifle rack on the right side front. It makes it even harder to get in and out that door. But it the best spot I found in my l5320.
I like the bucket hooks your putting. Good luck.
John
I had to replace the radio and speakers in my 4240 and again when I got the new 5740. Just in case you missed it here's the link.
http://www.tractorbynet.com/forums/customization/195848-time-upgrade.html
/ New Grand L5740 #47
When your "problem" is the speakers aren't good enough... well just try and open station tractor like some of us:( :laughing:
/ New Grand L5740 #48
Ya I realize that but you also have to realize your tougher than us cab guys and I'm not ashamed to admit it. :laughing: Well ok i am. :eek:
/ New Grand L5740 #50
:laughing::laughing: I will be getting a cab at all cost next time around. Starting to not feel "so tough":laughing:
/ New Grand L5740 #51
MTM,
The cab actually toughens up your hands. You would be amazed at the calluses one can develop changing from heat to A/C.
/ New Grand L5740 #52
Oh don't go thinking having a cab is easy. No sir. The other day I had to turn the heat down because the heat was killing me. At the same time a loud song came on the stereo and I had to reach up and turn it down. Yes it gets worst. Before I could reach up and turn the radio down I had to lay my coffee mug in the holder. It just gets to busy in the cab at times. :mad:
Man life isn't easy for us cab owners either you know :laughing:
/ New Grand L5740 #53
MTM,
Wow, that does sound rough!
Maybe you should let us "tough guys" have your cab tractors and you can have our open stations then, so it's not as rough on you:laughing:
/ New Grand L5740 #54
Good Afternoon High Compression,
Im jealous, all us open platform tractor owners just get the Work Tunes headset ! ;):)
Good Luck with your new machine !
My Work Tunes headset is junk. Lasted just over a year and the speakers started acting up. Now its hit or miss if they work or not so I just removed the batteries and use them as regular ear protection. I did get a new blue tooth that has a head phone option. You plug the blue tooth into ear buds and they are small and don't stick out very far so you can wear them with the hearing protection without too much discomfort (usually after a few hours they get annoying but at least they work).
I'm at the stage now where I won't buy an open station tractor again unless I really need it to be open. I spend way too much time on tractors and its just more enjoyable to have a dry, quiet, warm/cool operators station to be in for long hours each day. Of course it will take a lot more years before I can justify having all tractors with cabs but it gives me a goal :laughing:
/ New Grand L5740 #55
What goes bad on the WorkTunes is the cable going from side to side. It carries voltage from the batteries and also three other wires for the speaker. And flexes every time you yank them on and off. Take the thing apart and put in a new cable [ has to be at least five wire ] and she is good to go for another year. I use the units year round and have done this many times. Finally have to toss them out when the ear muffs go bad.
/ New Grand L5740 #56
I will try it over the winter. Thanks for the tip
/ New Grand L5740 #57
I will have to say that u have alot better visability then we do. Especially when blowing snow. Last night the defogger couldnt keep up. Hard to see all angles with the windows all steamed up. They steamed up because the snow was blowing on the windows. I guess better on the windows then my face.
/ New Grand L5740 #58
You using your A/C ? I had the fogging problem as well then started using the A/C on with heat on high and no foggy at all now. :thumbsup:
/ New Grand L5740 #59
High Compression said:
Thank you. As far as bucket hooks, on my B3030 HSTCC I frenched in a 2" receiver tube flush with the top middle of the bucket where I was able to pin in a hook, trailer hitch, winch etc. I'll probably do the same to the L5740. It is very handy. It is hard to take a plasma cutter and welder to the nice new orange paint, but it always turns out well with some new paint.
Heres a bucket hook suggestion, just made them up and installed the other day. Simple easy and didnt have to weld on the bucket. Just drill few holes and bolt on.
/ New Grand L5740 #60
I like the looks of those. Nice work! I think I'll use your design when I get the time to make some for mine. It is probably actually stronger being welded to the plate and bolted on, especially if you use grade 8 hardware. Is that 3/8" plate?
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A61572)
2025 HT360W Mini...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
