4720 Cab, Stuck Parking Brake.
/ 4720 Cab, Stuck Parking Brake. #1
Red Horse
Bolton, MA
Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
Well I bought a very clean 4720 Cab (200hrs) this week and right off the bat, the parking brakes would not release. I managed to free them-not sure how. Nothing as simple as the lever on my open deck 3320
Today I had it at the tire co to ballast the 44 x 18 20 Turfs and they called me to tell me the brakes would not release. I had to go over there to free them up (again I couldn't tell you how-combination of jumping on brakes, pushing/pulling red knob) and when I picked it up tonite-same deal. Its sitting on the trailer so I'll tackle in AM.
I called dealer and they suggested "someone was setting parking brake without depressing brakes". Accordingly, they probably bent the brake cable. so in the morning I'm going to pull the panel that is under the steering column and see what gives.
Any suggestions?
/ 4720 Cab, Stuck Parking Brake. #2
Seems to me they should be replacing it under warranty depending on the age. I've never had/heard of such problem. I won't be much use though I don't have anything close to this:(
/ 4720 Cab, Stuck Parking Brake. #3
I suspect what the dealer meant was that someone was pushing the parking brake release (red knob) without depressing the brake pedals. Normally I press the brake pedal(s) and pull out the know to set. Releasing the brakes you press on the pedals and lightly push the knob back in.
Correct. this machine is a 2007. the guy I bought it from let "friends borrow it". My suspicion is the "friends" should have been confined to a push mower never mind a 4720. Well I have the print of the parking brake components so wish me luck. I also did a search and I see this is a very common cab tractor problem. You would think there would be a factory fix for this by now. seems like as bad design.
/ 4720 Cab, Stuck Parking Brake. #5
Hard to fix "Stupid". Shouldn't be too hard to fix, good luck with it.
Fixed! Talk about a cheesy set up! The release cable is attached to the parking brake pall with a double bend. It appears at some point someone tried forcing the release button in without depressing the brake pedals and the cable got a slight kink in it.
Best way to get at this is to tilt the hood and you can see the pall and the cable where it is attached. With a long screw driver I was able to keep the cab le tight to the pall while a buddy pushed on the brake pedals-not a permanent fix as the cable probably has as "memory" now.
/ 4720 Cab, Stuck Parking Brake. #7
Good news.
Good luck with the tractor:thumbsup:
/ 4720 Cab, Stuck Parking Brake. #9
glad you got it fixed for now. I need to adjust my parking brake cable or retrofit the newer parking brake components.
Nuru- tell me more please! There is some sort of retro kit to replace the cable?
I'm thinking of making some sort of tool that can reach in to pull this cable if it does it again.
/ 4720 Cab, Stuck Parking Brake. #11
Someoone posted in one of the other forums that their 3720 had the holes pre-drilled for addding in the pull up parking brake from the newer JDs. That is all I known.
10-4, thx. I do believe the new ones (cab tractors) still have the cable set up.
/ 4720 Cab, Stuck Parking Brake. #13
I have a JD 4720, 2011 and the park brake has been redesigned from a pull up red leaver to a park break pull up arm...like you see in most small cars. your problem may have been a consistent problem for JD
"99"- A 2011 Cab tractor???
/ 4720 Cab, Stuck Parking Brake. #15
I have a 2012 3520 cab and they no longer have the red pull knob. It is the lever on the floor likke a car parking brake. Just as the other guy mentioned and is the same for the new 4x20 cab tractor
/ 4720 Cab, Stuck Parking Brake. #16
Red horse did you find a fix? My 4720 cab does same thing. Thanks.
Eric- YES! Check out..."Parking brake upgrade on 3000/4000 cabs". 40 bucks well spent. 3 pages plus pictures. Thx again to JD110 for posting the part number. Any questions let me know.:thumbsup:
/ 4720 Cab, Stuck Parking Brake. #18
$40 sounds like a deal. Will order one next time i visit my deere dealer Thanks!!
