Cheap Disk Project
   / Cheap Disk Project #1
grnspot110
Elite Member
MO
John Deere 1944- H, 1961 Cub Lo-Boy, 2016- JD 2025R, 2018- JD X580
This is what I've been working on the last couple of days! I started out with an old JD tandem drag disk ($50), used out of my scrap pile, except the two 5/8" x 4' rods for the rear support braces ($13) & some 1/2" grade 8 bolts out of my bolt bin. I still need to cut the rounded ends off the gang frame from the front section & weld them onto the off-set & switch some blades around (it had set in the dirt too long), then paint it next Spring. Should just cut out the tracks of the 790.
May not be the best disk around, but no more than I'll use it I can't justify buying one! ~~ grnspot
   / Cheap Disk Project #2
I like it !!!! :thumbsup: Show us some results some day.
   / Cheap Disk Project #3
Good project. I am like you I don't need a disc enough to buy new. Yours looks better than mine right now.
   / Cheap Disk Project #4
I was just thinking how much yours looks like mine. It works good for what I need, breaking up and leveling after plowing. I like the rear support braces.:thumbsup: Mine has quite a bit of flex when the 3 point is up. If the royalty fees aren't exhorbitant, I'm a gonna copy your idea.:laughing: Mark
You're welcome to it!
I will just use mine occasionally to seed some small plots, not even every year. ~~ grnspot
   / Cheap Disk Project #6
Can you guys talk about what a disk plow does? I have no idea
What we are discussing here are actually "disk harrows", generally used as secondary tillage after the ground has been plowed or chiseled.
The "disk plow" is a heavier tool, usually bigger disk blades in a single (angled) row. Use for primary tillage, in place of a moldboard plow.
In more recent years there is also a "plowing disk" available, which is basically a heavier "disk harrow". Again, used for primary tillage, before any other implement.
Hopefully I haven't caused more confusion! ~~ grnspot
   / Cheap Disk Project #8
pickeringchris - Just one way a disk can be used. In these two photos my son is turning a 30 acre weed patch under to de-compose in preparation for drilling / sewing cereal rye seed in sandy soil using a NHTD75D pulling a 10 ft. disk.
   / Cheap Disk Project #9
Looks real good:thumbsup:
2021 Delta Redirective Crash Cushion 75000 (A49461)
2021 Delta...
Kubota SVL95-2 High Flow Cab Skid Steer (A51039)
Kubota SVL95-2...
UNUSED Hydraulic Jack Lift (A50860)
UNUSED Hydraulic...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2001 Ford Excursion Limited SUV (A48082)
2001 Ford...
Miller Millermatic 130 XP Welding Machine (A50860)
Miller Millermatic...
