CK20 Box blade
/ CK20 Box blade #1
toddbiss
Enfield, NH
2011 Kioti CK20hst
Looking to get a box blade mostly for my driveway, It is kind of steep so what size do you guys think is best? 4 or 5 foot?
/ CK20 Box blade #2
I have a 5 ft. for my ct122 bobcat, which is the same tractor, and it pulls it fine :thumbsup:
/ CK20 Box blade
Thanks guys that is what I will go with. Any reason to keep my rear blade if I get a box blade? Mostly used the blade for the driveway but from what I read the box blade will work better.
/ CK20 Box blade #5
I sold mine, but the one that I had was pretty light duty ,every time I used it I would end up bending the mount. I think you will find a BB will do most if not all of the things your blade will do.
Craig
/ CK20 Box blade #6
I have a ck20 as well. I use my rear blade to dig/clear ditches and move the material to the center of my road. My box blade can't do this job. Both of the blades are 5 ft. Sometimes I get too much dirt in the box and the tractor breaks traction going up the hills. Easy fix.. 2 trips, shallower cut
2011 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A60736)
2011 TROXELL...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
Wooden Bench (A61570)
Toro z turn (A56859)
Manure spreader for sale
Manure spreader...
2009 IC Corporation PB105 School Bus (A60352)
2009 IC...
