pictures of skidder grapple
/ pictures of skidder grapple #1
mroldstyle
cataract wi
2003 New Holland tc 29d
Well I finally got around to getting a few pics of grapple in action.
What I've been doing is cutting 4 or 5 trees limbing them out and topping them off, then grabbing them and skidding them out to field, dropping them and spinning around and picking them up with fel and setting them down on skids to cut to length. Once cut pick'em back up and move to pile.
Been working well so far, now that I have a system worked out.
/ pictures of skidder grapple #2
That is nice. My whole theory of firewood production revolves around not having to touch the wood unless I have to. My theory of tractor operation is to not get off the tractor unless you have to.
/ pictures of skidder grapple #3
I agree with everything you say. It would help greatly if manufacturers put an automatic sandwich maker on their tractors.
/ pictures of skidder grapple #4
Nice unit. It will save a lot of time not having to get on and off the tractor. I like that the grapple pivots so you can adjust for grabbing the tree from any angle.
/ pictures of skidder grapple #5
Looks like it works good :thumbsup: Very nice.
Thanks for putting up the pictures of your working grapple.
/ pictures of skidder grapple #6
Looks really good, makes work a lot easier.
/ pictures of skidder grapple #8
Agreed! Lots of my firewood requires winching, so I have to get off for that.
Mrold - what are you burning there - looks like pulpwood? Is this for an OWF? Nice to have a flat field where you can yard logs. Good build.
Jim
/ pictures of skidder grapple #9
Nice job. Any problem with the empty grapple flopping around when driving over rough ground? I know my post hole digger is a pain when doing that.
/ pictures of skidder grapple #10
Great pics. Thank you for sharing them.
In the pic of the grapple holding the logs, is that showing how far it closes with the logs in place? Doe the logs stay in there like that? I've never done this, but I assumed that the skidder grapple had to close tight around the logs for it to hold them while dragging them, but it doesn't look like it in your pics.
Where are the stumps? Are you felling the trees with a chain saw and doing something with the logs? What are you doing with the logs?
Eddie
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2010 Honda CR-V SUV (A55853)
2010 Honda CR-V...
Takeuchi TB290 (A60462)
Takeuchi TB290...
CASE TV450B SKID STEER (A62129)
CASE TV450B SKID...
