Joystick handle and Horn install
   / Joystick handle and Horn install
Kenny - I know it's been a few years but I'm new to TractorByNet and I think you may be able to help. I'm not engineer and I need some guidence with regard to a joystick switch problem... I bought a JD 5325 back in 2004. It came with an ergonomic handle (like the one you installed). I ordered a WR Long grapple and had it installed at the dealer. I was horrified when it was dilevered with a new home-made looking blocked shapped handle and switch that had replaced the cool ergonomic one. They claimed that that was the switch and handle that had come with the grapple and if I wanted the egonomic handle, I'd have to purchase a handle that had the switch in it (the original handle that came with the tractor had a cut-out for the switch, but there wasn't one in it). So I purchased the new handle, installed it, but it would't work. I thought it was defective. So I returned it and got another. This time it worked for about 5 seconds and then stopped. Turns out, the switch is a different voltage or something and I was burning out the switch. But how to install a switch that could handle the load that would fit into the cool JD handle... I had given up until I saw your post. Do I need a "relay"? HELP! How to find and how to install. Thanks so much.
Welcome to TBN:D
Yes , you NEED a relay. The switch in the handle is just a small membrane switch and cannot take a lot of current. What valve form WR do you have? The true 3rd function or the Diverter?
Sent you a PM also;)
   / Joystick handle and Horn install #12
Hey Kenny,
I am getting ready to install my wr long electric hydraulic valve kit on my jd 3720 along with the 110 tlb handle and switch. Just wondering where you got your relay from? Thanks.
I replied to your PM...
   / Joystick handle and Horn install #14
. The UP/DOWN switch operates the diverter on the FEL, either UP or Down activates the diverter. The front single switch operates the horn.
Thanks for looking:D[/QUOTE]
kennyd
I'm new here but what is the Diverter for?
kennyd
I use it to operate my grapple, you need a 3rd function to open and close it.
   / Joystick handle and Horn install #16
Always nice to see a professional looking job as this one is. Really enjoyed seeing it. Good stuff sir :thumbsup:
Thanks 4S, I appreciate that:D
   / Joystick handle and Horn install #19
Can a horn magically summon lazy teenagers? I wish that I had one on my tractor so I could answer that question. They probably wouldn't hear it over the video games, but hope springs eternal.
   / Joystick handle and Horn install #20
Kenny,
Excellent job on the install :thumbsup:
What is the part number on the joystick? Thank You
Mike
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2017 Dodge Charger Sedan (A53424)
2017 Dodge Charger...
207010 (A55853)
207010 (A55853)
2015 John Deere 7700A Mower (A52377)
2015 John Deere...
TANK MANIFOLD (A58214)
UNUSED PABREAK BE232 HYD BACKHOE DIGGER ARM (A57193)
UNUSED PABREAK...
