John Deere #412 2 bottom plow
/ John Deere #412 2 bottom plow #1
Bob Senti
Ferguson TO30
Hello All,
I have a JD 412 2 bottom plow that I am pulling behind a Ferguson TO30. This setup seems overmatched and I was wondering what tractor the 412 was designed for?
Cheers,
Bob
/ John Deere #412 2 bottom plow #2
Seems like the plow is a shade too big. It seems very "robust" compared to other brands and Ive heard people say they pull hard. Was wondering if a TO30 could pull that.
/ John Deere #412 2 bottom plow #4
Your OP
Would you tell us how it pulls behind your TO 30 ??
I am in West Michigan, and we have very heavy clay here. I am new the plowing experience, and I am sure *I* am one of the variables that is making this difficult, but I want to make sure I am not using a plow that simply wont work for these conditions too.
I propped the tractor up on blocks about 8 inches on the left side on my concrete driveway so that I could level the plow off both front to back, and side to side, so I would have the best chance of success in the field.
#1) This all worked fine, but the first thing I noticed was the front coulter axle bracket assembly snags on the sway bar chains when I bring the plow up or settle it down to the ground. I can get it to go past it if I get out and push the plow over to the left (see #2) so its more centered as it drops, but that cant be the solution! A fellow suggested I remove the front coulter, but see my third point as to why that might not work either....
#2) Secondly, The whole plow tends to want to "drift" to the right when I lift it off the ground (standing still, not plowing) and I cant seem to adjust the right draw bar length or top link length in such a way to get the plow to balance more directly behind the tractor, even though it appears level to the ground. My fear is that when I do settle it into the ground it will not draw correctly because of this, and the 1st share will be too much behind the right wheel. I can minimize this some by adjusting the land slide, but its not ideal. I was thinking of shortening the right sway bar chain by a few links so it would keep it from going so far to the right but that seems like a patch to the problem.
#3) So, with all that being the case, I trucked out to my pasture. It is just that - an unplowed virgin pasture with about 4-6 inch tall grass (trashy!). I dropped her in and thinks were looking good but within about 15 feet the clay and grass had bound up around the coulters and plow bar, the clay quit rolling, and it was basically skipping off the top of the ground. I cleaned that up, and tried again, feathering the hyds and trying to go a little deeper to get a better "roll". That seemed to help a bit, but I quickly got bogged down again with trash.
It also seems to want to lift the front up. I can level her off and feather the hyds and that helps, but then it seems to come up out of the furrow and then Im done for.
I know there are a lot of variables. I just dont know how much margin of error I can have under these conditions or how precisely set these things need to be to work, and if a single bottom would be that much easier to work with?
Cheers,
T
/ John Deere #412 2 bottom plow #6
Hello All,
Cheers,
Bob
Deere plows pull hard. I would consider a 2-12 Dearborn or 2-12 Ferguson of the early fifties vintage. If the N series Ford's could pull those plows you won't have any trouble at all with the TO 30. Make sure the measurement from the center of the TO-30 drawbar to the inside edge of the right rear tire is around 23 inches. Ken Sweet
