Honda Rancher won't idle unless choked
   / Honda Rancher won't idle unless choked #11
While I do most of my own repairs , taking this carb apart , cleaning , installing kit, and re-assembly is not something I care to try presently. As pointed out in another post a new carb would probably be cheaper than taking to a dealer for service. Taking the old carb off and replacing with new one is something that I feel ok with , just not tearing into the innards of original.
It's not as difficult as you think, if you can take off a carb to replace it with a new one then you can easily clean a jet. You don't even need to remove the throttle cable. Just 4 screws to remove the float bowl, get a can of carb clean and spray it directly into the two jets. Reinstall bowl and go.
I like to remove the jets to clean them thoroughly but you can get by without removing them.
   / Honda Rancher won't idle unless choked #12
I have an 05 Foreman and have pulled the carb 2-3 times. I would not bother with a rebuild kit, just take it apart clean everything and put it back together the same way you took it apart. They are less complicated than people think, be careful when you take the bowl off of the float pin and the float jet that lets the gas in.
   / Honda Rancher won't idle unless choked #13
And, after your adventure is completed, spend 2 or 3 bucks and buy yourself a little in-line fuel filter.
An ounce of prevention is worth a pound of cure!!
Craig
   / Honda Rancher won't idle unless choked #14
Before buying a new carb, get some sea foam to mix with fuel and run a tank or two or more if you can through carb. BMW dealers had some stuff that was very potent for carbs and expensive. It is very easy to take the carb off though, and clean out the jets. Check on you tube, maybe someone is showing a how to on a atv.
   / Honda Rancher won't idle unless choked #15
I have a 2000 Honda Rancher that has been running 365 days a year, winter and summer, for 11 years now. Every now and then I have to "tweak" the carb setting screws. If I don't it won't idle right. The Honda service manual will tell you how to do this. If you have an older Honda the service manual is priceless.
   / Honda Rancher won't idle unless choked #16
Have 2005 Rancher 350 ES that has been flawless until today. Will not idle warm unless choke is partially on. Doing occasional spitting and sputtering also while riding. At higher rpm's it seems to be ok but when it idles down after letting off throttle it dies unless you feather the throttle,. Pulled air cleaner and shot some Seafoam into intake of carb and added some to gas tank. This does seem to have helped some but not to the point that it will idle correctly. ATV is stored in enclosed shed with full tank of 89 octane ethanol free gas(less than 500 miles on atv). Was ridden last around Halloween with no issues then. Not sure what could have caused issue since then, but suspect clogged jet or crud. This really surprised me today as this machine has been 100% reliable until this issue. Any ideas or pointers?
I would use up or get rid of the gas your using now, even mixing stale gas with fresh gas won't help. When you park it for longer than a couple weeks, turn the fuel petcock off wile idling and let it die out. Been doing that with my 2004 and no issues so far (knock on wood). Also as others have suggested-rebuild the carb.
   / Honda Rancher won't idle unless choked #17
What's the point of doing this?
If the fuel is going to go bad or create deposits, it will do it in the gas tank just as well as the carb. Running the carb dry and leaving it dry will only dry out the internal seals. Plus this will make it harder to start when you do want to use it. If it's going to sit for a while unused, put a fuel stabilizer like the Sta-bil Marine Formula which is designed for Ethanol gas.
   / Honda Rancher won't idle unless choked #18
i agree clean them jets and add a extra filter and by all means stay away from gas with ethenol in it that stuff eats up carbs fast . even if you use stabil i still don't trust ethenol.
   / Honda Rancher won't idle unless choked #19
Just a quick note. If you have not changed the spark plug, do so. Mine would go about three years and start doing exactly as you described. New plug, problem solved. Be sure and get a good plug. Go with the NKG or a good platinum tipped plug.
   / Honda Rancher won't idle unless choked #20
Jimmy,
This is a very good point! I had the very same issue with mine and it was a plug too. Good call......
Craig
2007 Ford Five Hundred SEL Sedan (A55853)
2007 Ford Five...
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A56857)
2025 Kivel Fork...
2018 KENWORTH T800 (A58214)
2018 KENWORTH T800...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A55315)
2023 Kubota U48-5...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
