Couple questions about my new CK27.
   / Couple questions about my new CK27. #11
I am surprised that the CK27 doesn't have a horn, the 20 does the switch is by the signal light actuater. Craig
Ya. No horn and no tilt steering. Which is ok cause the steering wheel position is perfect.
   / Couple questions about my new CK27. #13
I think horns are on units destined for outside the U.S. (mostly). Seems they may be a requirement in some countries. I do wish mine had one, and a kill switch too (another of those mistery options).
Some of the CK's have a backup light (manual trannies only???). Others may not have, and one of those connectors may be for that. There is also a "user circuit" with dedicated fuse in the fuse panel under there. This is perfect for user installed lights. do a search for add-on lights here and in customizations and you'll find all sorts of lighting ideas.
   / Couple questions about my new CK27. #14
What, no tilt steering or horn on CK27? They are standard equipment on Bobcat version. Horn is pretty wimpy sounding but it is there.
   / Couple questions about my new CK27. #15
My Kioti has a horn it, it's an "FEL in 4 wheel drive with a guy on it yelling ,"" get outa the way!!"":D
Did'nt work to good with my horses though, think they figered the FEL was BIG feed bucket!!
   / Couple questions about my new CK27. #16
The plugs are removed from the loader valve ports on the tractor when the dealer installs the loader.
The QD's are installed in their place.
They would only be used if you completely removed the loader, as in to sell it.
The wires are an extra circuit.
BTI
Do the DK's also have those two wires for lights? (I really need to add lights now that it is dark so early).
David
   / Couple questions about my new CK27. #17
David
I believe they do. Mine has rear facing work lights mounted on the sunshade. My dealer installed those options before delivery so I cannot be absolutely sure the wiring was standard. Mine has the light switch near my right shin, between ignition and floor.
   / Couple questions about my new CK27. #18
Not all have it. And the CK27's do have tilt steering. Though I've never considered that option all that useful. Others think it's a must. I'd rather have the shut off and horn, or factory roll bar lighting.
   / Couple questions about my new CK27. #19
Thanks Ed.
Just out of curiosity my hour gauge is 5 digits and says "2" I figured that meant 2 hours. Is that correct or is it .2?
Chris
There's no tenths on the hour meter, that means 2 hours. My CK 30 came with 3. I also don't have a horn but I read in another thread that the CK 35 does. They obviously make changes for different markets. My dealer added 2 work lights facing the back and two facing the front but he didn't use the extra circuit.
   / Couple questions about my new CK27. #20
My dealer did the same, but with only one light. I still have one set of wires available. (DK 35) unless prior to the dealer installing the light, there was 2 sets of wires.
2017 Wanco WSDT3-S S/A Towable Radar-Speed Trailer (A55973)
2017 Wanco WSDT3-S...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
2021 CTS T/A End Dump Trailer (A55973)
2021 CTS T/A End...
More info coming soon! (A55851)
More info coming...
2020 Ford (A55973)
2020 Ford (A55973)
2006 MAC TRAILER MANUFACTURING (A55788)
2006 MAC TRAILER...
