salt spreader tractor,ATV or WB?
   / salt spreader tractor,ATV or WB? #1
donn12
Great Falls Virginia
B2920 TLB turfs and loaded ags
I have been meaning to get a salt spreader for my 1/4 mile driveway and sooner or later I am going to get bit.
I have a herd 3pt spreader I could use but I am a little worried about rust on the tractor. It does get used for fertilizer and i have never noticed it getting pellets on the tractor but I will most likely keep this tractor forever or at least as long as I live here. I also may or may not have the backhoe on when the need arises.
I also have a Polaris 800 ATV. I could get an electric spreader for the receiver hitch. I am not so worried about rust on the ATV for some reason. I would also be more comfortable on this on a sheet of ice. Any recommendations on a good spreader for ice? Types of salt etc? I used to have a tow behind and one day after a few beers I dragged it up and down my driveway. I didnt see any salt on the ground - just 2 smooth tracks where the spreader wheels glided over the ice.
third option is a walk behind. Any recommendations? I am not exited about this incase I need to go out while it is still coming down so if i can figure something else out I will.
Thanks
   / salt spreader tractor,ATV or WB? #2
We have a 150 lb cap tow behind spreader. It works great for salt and fertilizer. The tow behind has a shield to protect our garden tractor and the tongue of the trailer keeps it far away.
Just be sure it doesn't have a plastic differential.
Earthway makes purpose built salt spreaders, they maybe worth looking in to.
Good luck.
   / salt spreader tractor,ATV or WB? #3
   / salt spreader tractor,ATV or WB? #4
I'm in the use what ya got category, a larger salt shield can be fabbed up if you are concerned about corrosion to the tractor. A quick trip to the salvage yard for an old car hood will yield more material than you will likely need.
2014 CATERPILLAR 966K WHEEL LOADER (A52709)
2014 CATERPILLAR...
LOT: Misc. Oils, Coolants, Tires (MOST OPENED OR PARTIALLY USED) (A59076)
LOT: Misc. Oils...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
19015 (A55788)
19015 (A55788)
2182 (A58376)
2182 (A58376)
