Home Built Roller using 300 gal. propane tank
/ Home Built Roller using 300 gal. propane tank #1
MyJoBota
Upstate New York
Kubota Grand L5740
One of those things where a heavy duty roller would be very handy but could never justify spending money on something used so little. Well after talking and bartering with few friends I was able to gather the materials needs to put this thing together with no out of pocket cost. I will more than likely spend a few bucks on painting it once the weather warms up though. The roller consists of a old 300 gallon propane tank welded up with a fill/drain added on one end. Some angle iron,square tubing,channel, and pillow block bearings. The roller is aprox. 9 feet wide and weighs aprox 300 to 400 pounds empty and I'm guessing 2500 to 3000 pounds filled full of water.
/ Home Built Roller using 300 gal. propane tank #2
Nice,
Just don't ever let it get away from you on a hill, it would roll right thru some one's house :eek:
If it really holds 300 gallons that would be 300 x 8.3 pounds per gallon = 2490 just for the water.
JB
/ Home Built Roller using 300 gal. propane tank #4
Nice build on the roller
/ Home Built Roller using 300 gal. propane tank #5
Uh, who welded the shafts on the ends and cut the drain hole? That thing is DANGEROUS if you don't have all of the hydrocarbons out when you weld and cut.
PS - I like the idea if you can do it safely.
/ Home Built Roller using 300 gal. propane tank #6
I think you could weld on it if it was filled with water.
I could not see. Does it have a wiper blade to clear off dirt? I built a roller and when I roll dirt with even the least moisture content, it sticks to the roller. Once it starts collecting, it really loads up. Of course, it you are only rolling grass, that probably would not be an issue.
The roller does have a scraper blade and these tanks are heavy enough gauge steel that rocks dont seem to be a issue. A friend of mine built one out of a 500 gal. propane tank a view years back to roll his grass landing strip and this one has held up well. The cutting and welding were done on the tanks with the valve removed and a inert gas(argon) flooded into the tank.
/ Home Built Roller using 300 gal. propane tank #8
I was thinking of building the same, only have been trying to figure out a way to do it on a 3 point hitch.
My Bobcat has a 1500 pound capacity, so I would only be able to fill it to that point
Do you know what the wall thickness was on your tank?
/ Home Built Roller using 300 gal. propane tank #9
If you still have the tag, it will tell the wall thickness (i.e. Shell THK .250" on a 1/4 inch wall) and other information including water gals and year built.
/ Home Built Roller using 300 gal. propane tank #10
That design would work well on a smaller tank ...do you have any close ups of the attachment of the tank to the frame? Did you use bearings in the design. Nice job and very clever !! Thanks for posting.
/ Home Built Roller using 300 gal. propane tank #12
Said it! Showed It! Yep! Think it's got Bearing!
/ Home Built Roller using 300 gal. propane tank #13
I hate to sound dumb but what do you use the roller for? We have about 10 acres of grass that a neighbor cuts for hay. It is clay and quite rough. I thought about getting a roller several years ago to see if I could smooth it out but after doing some reading I was afraid that the compaction it caused would negate any benefit I gained from rolling. I would like to revive the rolling idea if I could do it right and not do more damage than good.
A. Metcalf
A. Metcalf
We own a small horse stable and there is a 2.5 acres grass eventing field that takes some pretty serious abuse from the horses. I will use the roller on this field which is really like a part of the lawn and will roll parts of our huge country lawn. Would I use it on horse pasture and hayfield? I probably wouldnt for I have both pastures and hayfield that are relatively smooth.
/ Home Built Roller using 300 gal. propane tank #15
Thanks for the response and advice. I guess the rolling idea goes back on the shelf.
A. Metcalf
/ Home Built Roller using 300 gal. propane tank #16
There have been lots of debate on whether or not to roll lawns because of compaction. General consensus seems to be that if you have to roll it to smooth it out, you need to also regularly aerate to combat the compaction. The aeration is probably a good idea whether you roll or not.
