Where would you put an easement?
/ Where would you put an easement? #1
ITHINKICAN
Gold Member
Fort Bend, TX
Kubota
As you may or may not know (see other thread) a gas company approached us a while back. They want to run a 20 inch pipe under our property, and create a 30 ft easement.
Everything is still up in the air. Nothing is definite yet.
But my question is - where would you put the easement if you had the choice? We told them "do not disturb two large trees". So they proposed a 30 ft easement, pipe in the center at 42 ft from the property line. I am wondering if it would be better to let them take down the two large trees and run the pipe 15 ft from the property line.
Any suggestions? Thanks in advance.
/ Where would you put an easement? #2
Place the easement where it bothers you the least.
/ Where would you put an easement? #3
On my neighbors property.
/ Where would you put an easement? #4
I can relate as the gas company has an easement through my property. It was put in many years ago before my time. If they can put it in a place that doesn't affect any future plans of yours, it can be a good thing. Ours runs through a field that is cut for hay and will never affect any plans I have for the land. We get basically free gas for the use of our land, which saves big money per month on my electric bill in the winter. I would hope you would be getting some sort of benefit from it, otherwise I would tell them to find another route. Now a gas well would be another story. I own the mineral rights under my land, and a couple years ago, another gas company wanted to put in a well. I told them no way. I've heard, and seen, horror stories of the way they destroy your road and never put it back properly. Also would want the constant maintenance vehicles, noise, etc that could come with a well. In the 18 or so years I have lived here, I have never seen any maintenance people around. As far as keeping the trees or not, that will have to be a personal decision based on the shape of your land, future uses, etc. You only get one shot at it, so make sure you think it through and leave yourself with as little burden as possible.
/ Where would you put an easement? #5
put it as close to the boundry as you can that way if there are any issues to come you can fence it off and possible plant it out with shrubs etc to hide it ,,,,,,
/ Where would you put an easement? #6
If it didn't interfere with future plans, I would recommend that you have the easement placed as close to the property boundary as possible. That is what I would do if faced with this decision.
/ Where would you put an easement? #7
Only do it if you're sure it's worth it. (I have to assume there's some incentive to comply.) If it were me on my place I'd want it near the boundary line, preferably a corner near the road.
/ Where would you put an easement? #8
Try to put it in whatever is defined as building setback for your municipality. You can't build there anyway, so that should minimize future impact on your options.
/ Where would you put an easement? #9
If it were me I would lose the two trees and let them put it 15 ft. from your property line...like other posters have said. Here 15 ft. is the set back for any building and maybe it is the same there ...if so, then you have lost nothing and I am sure you are going to negotiate with them for compensation...Free gas for life sounds good...Remember your choice will affect the sale of your property some day...either by you or your heirs...
/ Where would you put an easement? #10
I would not want a big gas line anywhere under my property.
We just had a 36'' gas line explode in the SE corner of Ohio.
Destroyed 2 homes just from the heat of the fire which was 500 feet from them .
/ Where would you put an easement? #12
We have gas wells and gas lines running all over ^%$# up here in northern Michigan. The term easement means ATV/snowmobile/horse and hunting trail to a lot of people. You should also get some agreement on if they are going to add gates on your property lines, put wires across the line, or allow you to do so. Along with the easement, you give them the right to inspect and repair the line forever. So they need access. They usually don't want you to disturb the ground above the line, so that means no deer plots, farming, etc... you basically loose all rights to the property other than you can drive across it. I have a gate on the south line and a couple wires across the north line [properly marked with flourescent tape]. You have to keep after them to keep the gates locked, too.
/ Where would you put an easement? #13
I agree, let them take the trees and put it near the boudnary. Don't expect free gas for life either.
/ Where would you put an easement? #14
X2 Once you establish an easement you've set the grounds for expansion whether you want it or not. At the very least start at the property line as it may push expansion the other way, although it's doubtful. Find out what the neighbors are being offered & hold out for MUCH more. MikeD74T
/ Where would you put an easement? #15
Another thing, if you locate the easement right on your property line, you acutually have less control on it than if it is not on the line, and properly gated or fenced off. When it is on the line, it is more like a road easement since you only have control over part of the easement....so you basically kiss the property goodbye like the road easement.
/ Where would you put an easement? #16
These are all terms of the contract that can be negotiated. Make sure that you negotiate the terms satisfactory to your needs and wishes. An easement doesn't have to be a bad thing. It may be worth talking to a land use expert. It may be a lawyer. Your planning and zoning office or building code enforcement office can probably give you some good references.
/ Where would you put an easement? #17
As you may or may not know (see other thread) a gas company approached us a while back. ... ... .... . I am wondering if it would be better to let them take down the two large trees and run the pipe 15 ft from the property line.
Not having seen your property or the layout proposed it sounds like the best position would be as close to the property line as possible. You can also negotiate for replacement of the two trees or even relocation of them or payment for their value.
/ Where would you put an easement? #18
Trees can die. Pipelines are like herpes - you can't get rid of it once you have it.:(
/ Where would you put an easement? #19
It would be a strange easement if they don't allow you to use the surface. If you can not use the surface demand fair market value as if you were to sell it to them outright. You pay real estate taxes on land, so keeping an easement you can't use doesn't make much sense. They sure don't want to pay real estate taxes on thousands of acres of ROW. Remember, they try to do things as cheaply as possible.
Having the easement on your border is good, creates a buffer, better than running diagonally across your property.
/ Where would you put an easement? #20
The gas company can probably use immident domain and put the pipeline across your property whether you agree to it or not. Life is not fair and our government sucks. With that said, the Consitutions does state that they have to pay you just compensation, That is what gives you some bargaining rights. Holding out as long as possible does play to your advantage, they want to settle and want everything tied up in a neat little bundle before they start contruction. Waiting as long as possible to settle makes them more favorable to your demands, but caution is adviseable as well. If they can use imminet domain, and your demands they consider to be to unreasonable, they will just use the courts to take your land, where they want it, deposit a court determined amount in a bank account in your name, and then just proceed to do what the heck they want to do. At that point it will be up to you to sue them in another court to get any undetermined monentary amounts. If you cash the money they deposit in the account in your name, its the same as saying you are agreeing with their terms and from that point forward, its a done deal leaving you with no other recourse.
One other thing to consider, the person you are negotiating with is negotiating for the gas company and doesnot have your best interest at heart, no matter how sympathic they might sound to your concerns. They get paid to save the company money, period. If they tell you the company will do something, you better get it in writing before you sign over any rights, I will guarantee you if it aint on the agreement, the company wont do it, no matter what you where promised by the sweet talking person you negotiated with. If it aint in black and white, and it cost the company extra, then it simply aint going to happen.
2018 GRASSHOPPER 900D MOWER (A66091)
2018 GRASSHOPPER...
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
ALLMAND MAXI-LITE II V (A68842)
ALLMAND MAXI-LITE...
2022 INTERNATIONAL LT625 DAY CAB (A67714)
2022 INTERNATIONAL...
