Chain Bender
- Joined
- Feb 25, 2011
- Messages
- 244
- Tractor
- Kubota L3200
Today I made a balast weight for my L3200. I used 7 1/2 80# bags of ready to use concrete mix. I figure I added about 2+ gallons of water to each bag.
NOW......here's the question. How much weight will a gallon of water add to the concrete when it has dried. I know some of the water will evaporate through the top while it is drying, but the mix is in a plastic drum.
As I mixed each bag of concrete mix and poured it in the barrel I also threw in some busted up chunks of a slab made out of the exact same mix. I estimate I threw in about 100# of the chunks. I also think the internal welded frame and the barrel weighed about 40-50#'s.
I think the barrel will weigh in some where between 700 and 750 pounds. I have a 27" piece of 3/4" cold rolled round stock for lift pins. If I keep the lift arms pulled/pushed against the barrel as close as I can, will the 3/4" pins be strong enough? I know it's a little late to ask now, but I've been thinking about it since the minute I walked away from the barrel this afternoon.
thanks for your time.
CB
CB
