Synthetic oil
/ Synthetic oil #1
scazmando
'89 Cat D-4C, '40 9n, '58 601, '60's M/F 3165
Anyone have any thought's/ experience with using synthenic oil with older gas?/ diesel engines? I'm talking anywhere from a 1941 9-N to an '89 Cat 3204. Thanks for yor time.
/ Synthetic oil #2
I had a 1948 Farmall Cub. The oil was black and thick like tar almost when I changed it. Still ran great- good compression. -Used 10W-30 automotive oil and new filters after that.
If it is not broken- I don't like to fix things- leads to trouble.
An old co-worker wanted to clean his automobile out - get the last bit of power out of it. For weeks we heard about this. He planned to run kerosene for three minutes as fuel to clean the pistons, valves, rings etc., then go back to regular fuel in that nice newly cleaned engine. He used to complain that STP just would not do the job. A couple of weeks later I heard he had done as he planned. His car lost its compression, need a ring job, cylinders ground etc..
Sometimes it is good to leave things alone. Older engines were designed with the oil and fuel of the time they were built. Not all of today's products are retroactively good.
I've never rebuilt an engine. Someone who has can give you a much more substantial opinion.
Good luck.
/ Synthetic oil #3
They used to say that the seals in older engines would leak synthetic oils. This is not an irreversible problem. Try a synthetic and if it leaks, go back to dino oil.
I have not had any problems using synthetic in old air cooled engines (1980 Wheelhorse for example), and they seem to have better power.
I do not equate trying a synthetic oil with running an engine on kerosene (over the top in my book).
/ Synthetic oil #4
Synthetic oil has more detergent action than regular dino oil. You can loosen sludge from the engine and clog oil galleries. If you want to change over, do so by adding an additional quart at each oil change until you are running full synthetic. Sometimes the sludge is what is keeping some seals from leaking. When you remove the sludge, you may have some oozing from seals that you did not have with dino oil.
/ Synthetic oil #5
Moreover, the "getting every drop of old oil out" is the insanity of Harley Davidson owners. I don't get this. Why was the oil OK 2 miles ago but destructive now. Sure, change it but if some tiny amount of old oil remains so what?
The flight training platform I currently instruct with NEVER changes oil...just additives as required and topoff. Strap that on.
/ Synthetic oil #6
I was taught that oil actually gets better with use/age but the heat and dirt are what kills it. Plus it is easier to change it than clean it in todays "throw away" society.
David from jax
/ Synthetic oil #7
Lots of incorrect, and outdated advice out there on this subject.
Check the FAQ section of a synthetic oil manufacturer's web site, for facts. (Almost every oil maker has a synthetic product line now).
Short answer: If you, (a) need the ability of an oil to perform in extreme temperatures, either hot or cold, (b) need to, or desire to, operate at extended intervals between oil changes, then use synthetic oil.
If not, you should save your money, and run dino.
The only time you can't use synthetic oil, (in fact, you can't use regular dino either, because it has the same anti-wear additives), is if the engine requires a specific breaking period, and requires the use of a specified breaking oil. If they don't, it won't make a bit of difference either way.
/ Synthetic oil #8
x2 We switched all of our equipment at work and the synthetic will really clean up the insides. Sometimes that will make things leak. :)
/ Synthetic oil #9
My experience from syn in 1982 diesel.189k miles Expect more leaks and a lot more blow-by from the crankcase. Power seemed to be okay?It definitely cleaned out the engine? Worth it???Only if lifters or valves are sticking, better to add type f trans fluid to fuel, IMHO..
/ Synthetic oil #10
i replied in the other thread.
/ Synthetic oil #11
Some say not to use synthetic oil until the engine is broken in because it does not have enough friction. But there are many vehicles that come with synthetic oil as the factory fill.
/ Synthetic oil #12
That used to be the case. Syn oil was so efficient at lubrication that rings wouldn't seat. Manufacturing has gotten better, and tolerances tightened. The engines that come with syn oil from the factory are held to tolerances that don't require break in. It used to be that you were advised to do the first oil change at 500 miles. Things have gotten better since then.
/ Synthetic oil #13
Thank you LWG, I remember the days of 500 mile break in oil.
/ Synthetic oil #14
I switched to synthetic in all my vehicles, all are 9-10 years old. Not sure if it was a good move or not, seems to be using more oil. I wa told by someone that now I can't go back. Anybody know if this is true, that once you switch to synthetic, you can go back to dino? tks
/ Synthetic oil #15
I have done the same and much older. So far no problems. It was about 5 years ago on the 454 TBI in the MH at 92K miles and at 109K it still does not leak and still runs 3000 miles and only be a quart low at change time.
You can mix, blend, reverse usage at will. I have read newer spec'ed dino oil is about 25% synthetic already.
/ Synthetic oil #16
I switched from Rotella T 15-40 to synthetic Rotella 5-40 in my 90's B7100. The tractor starts much easier and quieter. Has not leaked a drop.
/ Synthetic oil #17
That incorrect advice is among the top ten wrong things people say about synthetic oil. Check the oil manufacturers web site.
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
Frontier QA Pallet Forks (A64126)
Frontier QA Pallet...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
