New member looking for advice
   / New member looking for advice #11
In Claremore do you really get the kind of snow that warrants a snow blower? At most of the airports I fly into, admittedly most larger than your strip, the prime snow removal seems to be medium wheel loaders with very large plows. Isn't your job to keep the runway clear during the snow so you have to be working at it continuously for while rather than waiting until the snow is over and then clear it off? Has the tractor you will be trading done a good job for you? My sister has a NH like the one you have been quoted on her farm and her husband and son can't keep her away from it. I think it would be a real good tractor for the job but I don't have any experience with the others. I have a Kubota but dealer service is not a problem - it's the same dealer that sold my sister the NH.
Also remembered another thing - you get ice storms now and then don't you? (I lived in KC for 22 years and have a general idea of your weather). I remeber windrows of ice along the runway at MCI - not very good if you only have a snow blower.
   / New member looking for advice #12
Grandad4 said:
Suggest you reconsider the snowblower. Nothing gets snow out of the way better. One that would fit tractors like this is in a whole different league from the little walk-behind models... check out the video:
Video Link: http://www.youtube.com/watch?v=GlZLVcIm_Mc&feature=related
Much more costly than a blade, particularly when front mounted, but it would virtually eliminate having 4-6 ft. snowbanks piling up at the edge of your runway after a major storm (wouldn't that be a safety concern?). With the blade, you'll end up pushing the snow out into the grass to avoid the snowbanks, vastly increasing the area that must be cleared, and eventually making ruts and a mess out there.
Looks like that blower is throwing a fair amount of driveway gravel. But hard to tell because I've never seen a blower bypassing the chute like that one is.
I'm on the side of getting a blower just for the ease of not having to clear lighting and signage. And a blower can move right along if one of its purposes is to keep the runway clear throughout a snow event. A good size blower/tractor doesn't have to crawl along on a well defined surface like a runway.
A FEL and a front mount blower would be nice but 3PH mount is likely the best way to go; just makes my neck sore watching someone use one.
   / New member looking for advice #13
Me too! If you're young and skinny, looking in back of you isn't much of a feat. For the rest of us, well...
   / New member looking for advice #14
The 8560 is an 8000lb+ machine. Lots of power and 17GPM implement pump. Get a snow blower that is hydraulic driven and mounts on the loader arms. It will pull a 15' mower without problem. These are VERY nice machines.;)
   / New member looking for advice #15
Grandad4 that is an amazing piece of equipment. Thanks for the video. From everyone's input, it looks like I could probably get the lesser hp tractor such as 38pto hp(mahindra 5010) with a 12 ft brush cutter, 8ft snow plow, and a snow blower all within budget. I will check with my dealers and see what they can come up with.
38 PTO HP isn't enough to pull a 12' bush hog, no matter what the ads say. In some cases it is barely enough to pull a 6 footer.
With that said, I think you need to shop around at some different Kubota dealers. You could get a M7040 4x4 cab tractor, with loader and 84" Kubota snow blower for about $43K, if you shop around. That leaves about $7K for a mower, which I think would be doable. The M7040 would have plenty of power to handle a 12' bush hog.
   / New member looking for advice #16
I would take some other things into consideration than price and brand like parts supply since this is an airport you need to look a down time major brands Kubota John Deere new holland and some others are going to have better parts supply than lesser brands for instance we have a Jd 6000 series and fuel pump went bad under warranty but was backordered so they went out on the dealers network and found one in Texas cost me 50 for shipping but we were fixed and farming again in 2 days
   / New member looking for advice #17
Thanks for the advice i'll keep in touch with this post and will ask for help of any thing if I need.
   / New member looking for advice #18
For airport snow removal you do NOT want chains on your tractor.
Foreign Object Damage is the ban of all aircraft, and chains have a habit of breaking off pieces which can be bounced and sucked into the worst places at the worst time.
   / New member looking for advice #19
Be sure to buy at least a 6 ft wide magnet to pull along and pick-up FOD.
Claremore is hit or miss on how bad the winters get, and last year was one that we needed a blower. In the past we have just waited for it to melt or the City bring out equipment to clear the runway, so the ability to be more self sustained and work continuously on clearing is the priority. The ford tractor has not done any snow removal, it was just for mowing.
I am most likely going to go with the 8560 because of the weight, additional hp, and warranty. The ability to run the larger mower is a plus, and with the addition of a plow we should be able to take care of business a lot more efficiently. My goal is to get the best tractor with the money allotted and implements such as a blower can be purchased later on.
Not sure where you got chains from, but I will not be using them. I intend to get at least the rear tires filled w/ fluid.
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
2000 Kiefer Bilt 20' Gooseneck Trailer (A59814)
2000 Kiefer Bilt...
2020 Diamond C Gooseneck Trailer (A57453)
2020 Diamond C...
Towable Diesel Generator (A59228)
Towable Diesel...
2007 Ford F-450 Chip Dump Truck, VIN # 1FDXF47P97EB35140 (A57453)
2007 Ford F-450...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
