Engine Oil Viscosity CT225/230/235
   / Engine Oil Viscosity CT225/230/235 #1
Spanky100
Gold Member
NE Texas, NE Tennessee, and SE MI and SW OH
Current Kioti CK27HST and Cub Cadet 1810. Previous NH1510 Hydro, AC D14, Oliver 1355?, and JD 314 Lawn Tractor
What engine oil viscosity does the Bobcat Owner Manual Specify for the CT225/230/235 Tractors? Just checking to see if they call out the same oil as the Kioti CK27/30/35 manual. I was surprised that 15W-40 was not shown for "summer" oil in the Kioti CKs.
The Kioti manual calls for the following SAE Viscosity by temperature range:
above 77 F (25C) SAE Viscosity 30w / 10W-30 / 10W-40
32 F to 77 F (0C to 25C) SAE Viscosity 20w / 10W-30 / 10W-40
below 32 F (0C) SAE Viscosity 10w / 10W-30 / 10W-40
Thanks
Spanky
   / Engine Oil Viscosity CT225/230/235 #2
Thanks
Spanky
I tried to paste the chart in from my CD's, but they wil not paste
Looks close but not exact
lilranch Thanks for trying to paste. Does it show any usage for the 15W-40 for warmer temps?
What is strange to me is that in my area - Midwest US, I have never seen a C_ rated "Diesel" oil available in 10W-40 SAE Viscosity. Only 10W-40 oils I see on the store/auto parts stores around here are S_ rated oils for "gasoline" engines. Could be a manual translation error from language or that a 10W-40 is available in other regions/countries.
I saw a Kubota oil post that showed the same SAE Viscosity listing as the Kioti Manual shows for the CK 27/30/35
Thanks
   / Engine Oil Viscosity CT225/230/235 #4
Thanks
15W-40 is 5F - 115F
lilranch
Thanks for the help.
Spsnky
   / Engine Oil Viscosity CT225/230/235 #6
Here is the Bobcat engine oil chart from the Operator manual.
SSdoxie
Thanks for the oil chart. Seems like the Bobcat oil recommendation chart is more realistic then the written information in the Kioti CK Manual. One dealer I talked with said he felt the Kioti Manual was either a bad translation or a mistake.
Thanks again
Spanky
36FT. B-Tek Centurion 100 Ton Digital Modular Commercial Truck Scale (A56858)
36FT. B-Tek...
2004 DITCH WITCH 3700 RIDE ON TRENCHER (A52709)
2004 DITCH WITCH...
HEAVY DUTY 7' ROTARY MOWER (A52708)
HEAVY DUTY 7'...
Enerpac RCS302 30-Ton Hydraulic Jack, 5" Tall (A59076)
Enerpac RCS302...
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
(INOP) 2019 KOMATSU D61PX-24 CRAWLER DOZER (A52705)
(INOP) 2019...
