Cub Cadet RZT 50 - Ongoing Reviews
   / Cub Cadet RZT 50 - Ongoing Reviews #61
I tried the wash system on my RZT 54 one time...thought it was useless too. You are better off just running the front end up on ramps and the using a pry bar or large screwdriver to dig the clumped grass from the deck.
   / Cub Cadet RZT 50 - Ongoing Reviews #62
I also purchased a used RZT 54 (2010) with 49 hours and the Kawasaki engine. I have around 79 hours on it now and have a broken deck height spring. Anyone have to replace one of these springs yet? Is this going to be a pain?
I have also noticed that when backing up, one side is much stronger and makes it difficult to keep the mower in a straight line. Will belt tension cause this, or am I one of the lucky ones that have Hydro problems? Also, which tranny do I have? The sticker on the tranny just states "Hydro Gear ZH MNBC 3BDC 4RRX". Any thoughts - Thanks!
   / Cub Cadet RZT 50 - Ongoing Reviews #63
With the deck off the spring is easy to replace.
The transmission is a ZT-2800.
You may just need to clean and adjust the stering linkage to correct the reversing problem.
   / Cub Cadet RZT 50 - Ongoing Reviews #64
The only trouble I have going backwards appears to be traction related. One side slips more easily than the other. However, if I ease backwards gently, the problem seems cured. Look the wheels next the you reverse to see if your problem is the same. Does the 54" model have the cutoff feature when the PTO is engaged and both arms are full reverse?
   / Cub Cadet RZT 50 - Ongoing Reviews #65
I had to do some adjustment on my RZT54. Specifically, on the handle stops and on the lengths of the heim joints that connect the handles to the hydros underneath.
   / Cub Cadet RZT 50 - Ongoing Reviews #66
Yes, the 54 "had" the PTO cut off. I've tried pulling both levers: slowly, quickly, and one before the other but it still didn't matter. It's not the tires spinning either. Thanks for the reply though.
   / Cub Cadet RZT 50 - Ongoing Reviews #67
This would be worth a look - thanks!
   / Cub Cadet RZT 50 - Ongoing Reviews #68
Yep. When I received mine (in crate form), the thing wouldn't go straight when both handles were all the way forward. That was with the handle adjustments (from above) to be all the way out front. There is a double nut "stop" on each side of mine that can be adjusted from above. However, even with the "stop" adjusted all the way down, mine still wouldn't go straight. I had to get underneath and adjust at the heim joints. No big deal really.
Are you annoyed at all with your deck cutting out when you are in reverse? If so, let me know...I "fixed" mine...
   / Cub Cadet RZT 50 - Ongoing Reviews #69
Annoyed and a little concerned that the PTO would quit working before long. I crawled underneath and made a few "adjustments" to take care of this.
   / Cub Cadet RZT 50 - Ongoing Reviews #70
What's the deal with replacement blades?
I go on Fleabay while at work figuring I'll just order some blades so they show up for the weekend & I can throw them on.
Not so easy!
I see that there are no less than three different center hole patterns.
Needless to say, I don't have the manual or the part number to cross reference while at work.
& while I'm on the subject of blades,
Would it be better to get the "gator" blades or stick with the originals?
I have about 2-3 acres, no mulching.
Thnaks
Vince D
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A55301)
Gooseneck...
2014 Ford F-150XL (A53314)
2014 Ford F-150XL...
Giy Land Leveler (A53316)
Giy Land Leveler...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
New Holland LS170 Skidloader (SALVAGE) (A50775)
New Holland LS170...
