Pump Id needed, Please help
/ Pump Id needed, Please help #1
sdom001
Homemade
Does anyone know what model hydraulic pump this is. All it says on it is Eaton. The closest I've come to id myself is an L2 model gear pump but not sure.
Any help would be appreciated.
/ Pump Id needed, Please help #2
I have a similar pump by Eaton.
That pump turns clockwise looking at the shaft.
If you can fine the stamped number, there is enough data here to tell you everything you want to know.
There should be a number on the flange. Take some pictures all around the flange.
Use a wire brush and clean all around the lip of the hyd pump, and put your camera underneath the pump and click off several pictures, or use a mirror to see the numbers.
Numbers may be stamped on the lip of the mounting flange.
http://www.ehow.com/info_7814720_specs-eaton-l2-gear-pump.html
The nine Eaton Series L2 models are numbered from 25500 to 25508. Model 25500 is the smallest Series L2 gear pump, with a displacement of 1.30 cubic inches per revolution.
Read more: Specs for an Eaton L2 Gear Pump | eHow.com http://www.ehow.com/info_7814720_specs-eaton-l2-gear-pump.html#ixzz1eZt8yKse
http://www.go2hydraulics.com/docs/mfr/eaton/eaton-series-26-l2-pumps.pdf#page=25
Page 25
Thanx, I found a serial number on the mounting flange but it doesn't match what you gave me. I'm going to take it off of the mount and look all around.
I'll post what I find.
/ Pump Id needed, Please help #4
Post the number and others can help you search.
That number was just for reference.
The only serial number I can find is here in the picture it looks like it says
F400-V-307W the 3 may be a 5 not sure.
anyone know anything. any help would be greatly appreciated.
/ Pump Id needed, Please help #7
That number looks like someone put that n umber on with an engraver. The Eaton number is usually stamped on the outside of the flange, or stamped on a tag.
This is similar to the numbers stamped on my Eaton pumps.
Single Pump - Product Number:
7 0 5 2 3 - R A A
This is what the numbers mean.
A - Product Number Description
70523 = Single Piston Pump
70553 = Single Piston Pump, w/ Aux. Flange
B - Rotation
L - Left Hand (CCW)
R - Right Hand (CW)
C - Sequential Numbering
/ Pump Id needed, Please help #8
Is this off of a transmission or gear box? It doesn't look like any "standard" pump configuration I have ever seen.
To be honest, I don't know what it is off off. It's a hydraulic pump on a homemade tractor that I bought and am restoring.
That's why I was trying to id it so I knew what it was capable of.:)
/ Pump Id needed, Please help #10
It could be from Eaton's Fuller division (transmissions).
Vane pump? Just guessing...but something to look into.
I was able to look inside from behind where the hoses attach. it's definitely a gear pump.
/ Pump Id needed, Please help #12
Do some looking around for Cessna pumps. Probably a Cessna.
/ Pump Id needed, Please help #13
The pump is made by EATON. Look at the pictures. It turns clockwise.
/ Pump Id needed, Please help #14
Cessna is an Eaton brand...like Vickers or Aeroquip. Still thinking it's a Cessna...
/ Pump Id needed, Please help #15
Didn't Eaton also a have a gear pump line based in South Carolina prior to the Cessna buy out? Or was this Vickers and then Eaton bought Vickers? This looks old enough to be prior to Vickers Eaton merger.
from the pictures I've seen online it looks a lot like the Eaton l2 gear pumps but just enough different.
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
2022 New Holland C327 Compact Track Loader (A63118)
2022 New Holland...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2015 Jeep Cherokee 4x4 (MPV), VIN # 1C4PJMCS3FW530016 (A61165)
2015 Jeep Cherokee...
3ft. 5-Point Metal Star (A61569)
3ft. 5-Point Metal...
500BBL WHEELED...
