Ford 1920 Issue number 1 of 2
   / Ford 1920 Issue number 1 of 2
Glad to see it ended up working out for you :thumbsup:
The round hole under the seat is where the shaft to engage the FWA would be. It is just a round rod with a handle on top to push up to engage FWA or push down to disengage. Since yours in 2wd you don't need to worry about it.
The price for the front grill screen was stupid the last time I checked so I left mine dented and bruised. I didn't see any reason to replace it at that cost when a stray limb will damage it quickly again.
Thanks Robert. I was thinking of checking some Ford salvage yards for a better grille, since that was is so rough.
One rear fender is also pretty dinged up.
But things are looking up!:thumbsup:
   / Ford 1920 Issue number 1 of 2 #32
mine had 3+r on the column, and 4 ranges beside the seat.
as for the hyds.. hard to add? no.. expensive to add? Yes.. :)
at least for the oem add on pack.
might tap into the adapter block at the side of the engine, a dna dd some kUsToM valving to save a few bucks...
soundguy
   / Ford 1920 Issue number 1 of 2 #33
Hi Soundguy. Yup, it moves great. Please check out the video if you get a chance. It was the lever to the left of the drivers seat looking down. It selects four ranges, but then the one on the dashboard only seems to have forward/neutral/reverse, but the chart on the rear fender seems to indicate it should have 3 x 4 for 12 gears total, can you look at the video and set me straight on this???
The lever next to the steering column should move left to right as well as back and forth. There would be three forward gears and one reverse. The reverse is left and down and the forward gears would be left/up, right/up, right/down. Then you have the 4 ranges which gives you a 12x4 tranny. Of course my memory is really bad so trying to remember this particular tractor is tough and I am recalling similar transmissions from my past.
   / Ford 1920 Issue number 1 of 2 #34
yep, I can't remember the exact column shift pettern on that one either. traded my 1920 in about 2002 for my 7610s
soundguy
   / Ford 1920 Issue number 1 of 2 #35
Glad to see you got it going without spending any money.I think you should have 3 forwards plus reverse on the collum. See if you can find an operators manual on line. Here is one I found FMF - Ford 1920 Tractor - Operator's Manual - $9.99 You cant beat the price and it should explain how every thing should function. You can instsntly download after paying.
Bill
Thanks for the link Hooked on hp, I'm downloading the operator's manual as I type this post. When I get the wheel back on, I'll try playing with that lever on the column to find/test the other gears.
Oh, my download of the manual just finished, yup, looks good. Looks like the missing parts of my broken dash had the gears written right on it:laughing:
Cool beans!
Repacked the front wheel bearings, and turned flipped the front wheel around to correct the issue of the tire sidewall rubbing that bolt head. Notice in the operator's manual that this was a normal way to change tread width. Then I notice the side that was not rubbing already had the wheel turned that way. Now with both valve stems faceing inwards, no more rubbing issue.
Boy are those foam filled tires heavy!
After getting the wheels back on, I test drove, and checked out the gear shift question we were talking about, and yes, it does have three speeds forward, and 1 reverse on the column.:thumbsup:
One thing that did happen, when going at high speed down the paved road, at one point the front end got a little "squirrely" on me. Wheels did a little side to side shimmy thing, but I slowed doen and it was okay.
Steve.
   / Ford 1920 Issue number 1 of 2 #38
try to locate the play.. I guess you can rule out hub and bearing.
might still be rim / tire, or back..
   / Ford 1920 Issue number 1 of 2 #39
I would check the toe on the front tires. As bad as the are worn you may need some adjustment. Are you sure the tires are foam filled and not liquid filled. I wouldn't think foam would be that heavy. Now for the nosey question. What did you give for it:D.
Bill
   / Ford 1920 Issue number 1 of 2 #40
Bill
Foam filled tires are wicked heavy.
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
Bogballe L20W Plus (A53317)
Bogballe L20W Plus...
Deere 310SK (A57148)
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2020 Aluma 20' Trailer (A59814)
2020 Aluma 20'...
