Buick has a weird brake glitch
/ Buick has a weird brake glitch #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
Redid the brakes on my '04 Lesabre less than 4,000 miles ago, in the last month it has been acting really strange about every 50th time I apply the brakes...the pedal pulses back and it acts like the ABS is kicking in, even though the pavement is dry. No, this does not happen during a hard or emergency stop, because I don't do those. When I release the pedal and reapply the brakes, nothing happens, until about the 50th time when it acts up again. For what it is worth, car is only driven 1-2 times per week, and the pulse back never happens unless it has been driven for several miles. Any ideas?
Thanks.
/ Buick has a weird brake glitch #2
I've been told that GM products have a terrible brake system. When I think about the 2003 Pontiac we had it's very true.
A split rotor may act as you have desribed.:)
/ Buick has a weird brake glitch #3
Relube the caliper slides, because you don't drive it a lot, any slight hangup in the slide will trigger a false ABS condition. While it is apart you should unplug and clean the sensor connections with electrical contact cleaner as well.
/ Buick has a weird brake glitch #4
If this is happening at a slow speed, when coming to a stop, it is most likely an abs stop taking place. This is common on GM cars and is usually caused by a wheel speed sensor going bad. The way to check this is to scan all four wheel speed sensors while driving and see which one is dropping out when the problem occurs. What the abs controller sees is one wheel showing 0 mph when the other 3 show 3 or 4 mph and so it thinks that wheel is skidding and activates the abs system untill all wheels are the same. This is easy to see with the right scanner, preferrably one that allows graphing of the signals from the speed sensors.
/ Buick has a weird brake glitch #5
when the sensores go bad isn't there an ABS light that comes on?:)
Thanks Guys, I should have mentioned that the glitch happens at brake applications of 35-55 mph and the ABS light doesn't come on. I like the suggestion about lubing the caliper slides...appreciate the detailed input.
/ Buick has a weird brake glitch #7
If you have a polishing wheel (not grinding) on a bench grinder, don't be afraid to clean them with brake cleaner and polish them up before regreaseing them, the end goal here is to get them to slide easily. Don't forget a dab of locktite on the caliper bracket bolts too.(blue not red!)
/ Buick has a weird brake glitch #8
The light will come on in the case of a open or shorted circuit. In the case of false ABS application as described by Auto Mech the wheel speed sensor is dropping it's signal as it comes to a rolling stop and the computer in charge of things is unable to see anything other then one wheel locking up and so reacts by activating the abs, same as if you had stopped on some ice.
In the light truck line it was rust building up under sensor pulling the sensor away from the tone wheel. This resulted in the signal dropping out at slow speeds.
If the problem is not ABS related then something is loose and shifting around, loose caliper, loose pad material ect. Good visual inspection is in order. Good rule, "first place to look is the past place you have been".
/ Buick has a weird brake glitch #9
GM doesn't have terrible brakes, and it's most likely sensor related, as mentioned, either a bad one or rust causing false signal.
When I redid the brakes I used better than OEM quality pads and rotors and since the car was outside at the time I powerwashed the calipers well after removing the old pad and rotors. Also used a brass wire brush to remove and clean any debris the power washer and used brake cleaner on anything that didn't look clean enough. BTW the 4,000 miles between brake redo and the first time the problem surfaced took over and year and a half to put on the car. I should have mentioned that after the second time the problem occurred I pulled all four wheels to check for something loose with no success. Thanks guys...I don't think the problem is serious enough to warrant any worry but now if it become more frequent I will have ideas to check on...:thumbsup:
And roygage, my 2000 GMC Yukon XL had a factory recall for that rust buildup under the sensor...I did the cleaning myself, very minor rust. I didn't think that problem could also affect my car...thanks for the heads up !!!
/ Buick has a weird brake glitch #11
GM doesn't have terrible brakes, and it's most likely sensor related, as mentioned, either a bad one or rust causing false signal./QUOTE]
My 2003 Pontiac Grand AM might not agree. :(
Fortunetly it found a new home after the brakes were redone for the third or fourth time.:thumbsup:
/ Buick has a weird brake glitch #12
You might have had a bad one, there might be models with bad brakes, but to say GM, Ford, Toyota, etc... have bad brakes is painting with an awful broad brush, that's all I'm saying.;)
/ Buick has a weird brake glitch #13
You might have had a bad one, there might be models with bad brakes, but to say GM, Ford, Toyota, etc... have bad brakes is painting with an awful broad brush, that's all I'm saying./QUOTE]
Don't think I mentioned any other makes.:)
My Y2K GMC still has OEM brakes, just had a tiny issue with the rust build up on the fronts. My '04 Lesabre should have gone a lot further than 49,000 miles on the OEM brakes but my wife used to drive it and she is the most terrible brake abuser, has no thought of coasting up to a stop sign, just roar up as fast as possible and slam them on hard. Our '04 Saturn still has OEM brakes with 52,000 miles, no issues.
/ Buick has a weird brake glitch #15
I don't think you did either, which was my exact point. GM specifically doesn't have bad brakes anymore than other make.
/ Buick has a weird brake glitch #16
I don't think you did either, which was my exact point. GM specifically doesn't have bad brakes anymore than other make./QUOTE]
A few years ago an Area represenative of a well known Auto Supply Store told me the GM brakes could be better. One thing he did mention was the senors clogging up or becomeing disabled.
I kinda figure the sensors are an integral part of the brake system.:)
A quik Google and seems I HAD company::( The replacement vehicle behaves very well.:thumbsup:
Brake or Rotor Problems? Premature Wear?
Have you or are you currently having problems with your GM, Chevrolet, Oldsmobile or Pontiac brakes or brake rotors? You are not alone! 1000's of other consumers have had to replace their brakes or brake rotors due to premature wear. According to Autoweb's Reliability and Satisfaction Ratings:
28% of Chevrolet Impala owners reported problems with their brakes or brake rotors. See Autoweb Report.
44% of Chevrolet Malibu owners reported problems with their brakes or brake rotors. See Autoweb Report.
And a whopping 51% of Oldsmobile Alero owners reported problems with their brakes or rotors. See Autoweb Report.
Some of the most common reported brake problems include: brakes squealing or grinding, brakes and/or steering wheel pulsing and rotors pitting, rusting, distorting, wobbling or warping. Many of these problems are due to excessive heat, rapid cooling. Additionally, the excessive wear and tear may be attributed to reports that an inferior metal composite has been used in the manufacture of the brake rotors, which were made smaller and thinner, and therefore, less able to absorb peak heat without problems.
What's most alarming is the frequency with which the brake problems reappear. After having their brakes and rotors replaced, consumers report the pulsing, grinding and squealing reoccurring within 3000 - 7000 miles, eventually leading to yet another replacement, which falls well short of GM's guideline of brakes being expected to last 12 months/12,000 miles.
The brake problems affect a wide range of 1997 - 2003 GM cars and trucks, including Chevrolet Malibu and Impala, Pontiac Grand Am and Grand Prix, Oldsmobile Cutlass and Alero and many other makes and models.
If you would like to know whether or not a legitimate claim for recovery under the lemon law is available to you, take a moment to read through this web site and send us your information. Or contact any of the attorneys listed. There is no cost or fee for doing so.
/ Buick has a weird brake glitch #17
Any brake job is 50% parts quality and 50% installation, after that no two are alike...environment plays a huge factor, do they go thru "touch less" washes with chassis wash? Were the rims cleaned with wheel acid? Do they like to shine their tires? Was the car driven over recently redone roads or other dusty abrasive conditions?...I could make a list a mile long but, the fact is brake life is relative to a million factors, something as seeming meaningless as the drivers bodyweight will affect the wear.
/ Buick has a weird brake glitch #18
First page I clicked had 8 Ford models with similar issues, 6 Toyota's and 6 Nissan's. Like I said, it ain't GM any more than anyone else.;)
1 example;
Ford Flex Problem
9 ReportsMe Too Edit Model Years Affected: 2009, 2010, 2011
Average Mileage: 27,000 mi (9,000 mi - 56,000 mi)
Verified
Defective anchor brackets for the front calipers can cause abnormal brake rotor and pad wear concurrently. Noise can be heard while braking, a grunting or grinding from the front. The caliper anchor brackets should be replaced with revised parts, and also replace the rotors and brake pads.
2018 Chevy Silverado 1500 4X4 (A61306)
2018 Chevy...
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
Miscellaneous Mini Excavator Attachments (A59228)
Miscellaneous Mini...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
(INOP) 2002 FORD F-350 XL SUPER DUTY FLATBED TRUCK (A60430)
(INOP) 2002 FORD...
2018 Kia Soul SUV (A59231)
2018 Kia Soul SUV...
