RTV1100 Cab leaking
/ RTV1100 Cab leaking #1
tn123
Kubota RTV1100
Hello,
Has anyone had the front window seal leak on their RTV1100? It's getting the radio wet during heavy rains...The dealer replaced the top shell due to a crack, then siliconed the seals but it still leaks a bit.
/ RTV1100 Cab leaking #2
Hello,
I'd send it back to the dealer...I've never had a leak...Although mine stays inside, I have run it in snow/ice/rain storms and never a drop. It's sealed so tight, it's hard to close the doors.
/ RTV1100 Cab leaking #3
Yep mine leaks in the rain around windshield, has since I bought it 3 years ago.
Keep it inside most of the time so never bothered to fix it.
/ RTV1100 Cab leaking #4
Yes , mine was first one the dealer sold. Never took it in, the overhang of the roof should help but it gets sucked up there in the crack and it drips. Does not do it as much now though, kind of hard tohave it hinged and then clamp the seal all the way around when it is closed, maybe they need some hints from the mini van makers on this one.
DAvid Kb7uns
/ RTV1100 Cab leaking #5
what i have noticed is stuff gets in between the seal and the window, if you clean it out it will reseal
/ RTV1100 Cab leaking #6
Hello,
no issues on my 2009 - but passenger door has a gab i can see thru...
/ RTV1100 Cab leaking #7
Yep bought mine new in 2008.Always leaked right on the radio kept inside so never bothered to fix.First radio only lasted about 6 months anyhow!
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
2004 John Deere 8320 (A63688)
2004 John Deere...
213063 (A64276)
213063 (A64276)
Ford F800 (A63689)
Ford F800 (A63689)
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
