Splitter Build Begins
/ Splitter Build Begins #1
165masseyky
Albany Kentucky
massey ferguson 165
After several weeks of thought and research. Trial and error and more error and nearly a trial I have decided my 165 MF doesn't have quite the juice needed to do what I need from my splitter so I am gonna go another direction. Instead of relying on my tractor QD's I have decided to run from a gas engine with a shaft pump. After contacting Northern Tool(who btw has what I believe to be the best customer service in the free world) I have returned the unused belt driven pump that I had traded for and now have $530 to spend toward this project in the form of a Northern Tool gift card. I have located a twin cylinder 16.5hp Briggs engine that I can trade for with little to no money invested. I have chosen a 16 GPM 2 stage 3000psi pump that I will couple to the Briggs and also ordered a 20gal tank with large screw in screen along with a 5in x 2in x 24in Hadaven cylinder.
I do have a concern though. The pump doesn't list a return pressure so I don't know what PSI filter I need to purchase. It is a Haldex pump so maybe someone can help me with this.
The specs I got from my math for this set up should run a very satisfyingly productive system. I also have a Prince LSR 3060 detent valve that would make the extend very quick but could cause some serious hydraulic heat issues I fear.
(without LSR valve)
Push lbs -58905-29.45ton
pull lbs -49480-24.74ton
extend speed-7.7
retract-6.5
cycle-14.2
I know that isn't a blazing speed but with this much pressure and my 1/2in H beam I can make multi split passes with ease I believe as long as my Hydra. temps don't get to high. I was able to trade some with the local hydraulic shop and got the 5in bore for about $150 new. Not bad so I will pat myself on the back now. The H beam was a freebie...well sort of I got it by helping the local scrap yard guy load some steel on a trailer. Took about 3 hours. Built the pusher sled out of scrap I scrounged from the metal bin at work. My hoses I had made and were $227. To this point I have figured I have ruffly $550 in the same materials you would find in a $3000 splitter. Now the work starts. I have a 4x8 diamond plate decked trailer that is going to be sacrificed for the frame and transport unit.
So here is what I am thinking. How bought we do this as a group. Lets here suggestions of what would be a good thing to have engineered into a splitter and what things have been tried and were less than a good return. I want to finish this build and dub it "TBN1". So who is up for this the sky is the limit and no idea is too wild. All suggestions will be considered and in one week we should have enough of a design to start the build. Only restriction is the H beam is 6' 6" long and the rest is up to us.
Might be a good idea to set up a list of details.
.Safety
.Hydraulic
.Power
.Log Lift
.Log stabilizer
.Fuel capacity
.Wedge
.Transport
.Tools and Storage
.Spare Parts
.Paint scheme
After reading tons of posts from this site I think this could be an awesome endeavor an not to mention a lot of fun to see just how far the brilliant minds on TBN can push them selves.
/ Splitter Build Begins #2
Boom with winch, to drag in rounds too far and too big to roll to the log lift
/ Splitter Build Begins #3
I only have two suggestions
1st, (and JJ will probabally be along to clarify), but I do NOT think you can run that regen valve with the 2-stage pump. I think you need a standard logsplitter valve.
2nd, with the 16.5HP motor, and 5" cylinder, I'd seriously consider the 22GPM pump. It will make better use of your HP, and make the huge 5" cylinder blazing fast:thumbsup:
/ Splitter Build Begins #4
Yep, you are right about the fast extend valve. It does not work with two stage pumps, and it also only works with low GPM single stage hyd pumps .
The relationship about the GPM's between the two kind of pumps, is that the performance/speed is about equal. The fast extend/regen valve takes low GPM, and adds the fluid from the rod side to gain more GPM's.
Suggestions about the pump will have to be based on the HP you have available.
A 28 GPM two stage pump will need a 16 HP engine.
Surplus Center - 28 GPM DYNAMIC 2-STAGE PUMP
The Prince Auto valve
Surplus Center - 1 SPOOL PRINCE AUTO CYCLE LOG SPLITTER VALVE W/PB
Log lift, wedge or winch possible.
Surplus Center - 2 SPOOL 25 GPM PRINCE RD526GCGA5A4B1 OC VALVE W/FT
/ Splitter Build Begins #5
flatheadford. Right on with the winch and boom. I have mine set up with an A frame over the splitter jaw. Sure takes the work out of moving the big ones around. The other thing is a T knife so the block stays whole while taking two pieces off the bottom with each stroke.
Thanks thats what I was thinking so I have already dug out the other 2 spool valve for the use of the 22gpm pump.
I am leaning towards the 22 gpm I think the big bore cylinder will give me plenty of speed and power now that I do the math so needing a downshift pump won't me needed what do you think? Is there a difference in performance that would make you pick the two stage over the straight 22 gpm? And I have a question about the 2 spool valve you mentioned are both spools auto or only the spool for the splitter and not the acc. spool?
/ Splitter Build Begins #8
J J wood splitting is a never end learning process CRThomas
/ Splitter Build Begins #9
Auto-Cycle valve allows operator to completely cycle (out and back) a double acting cylinder by only one handle movement. It uses two spools to operate one cyl. Accessories valve is separate valve for things like log lift and wedge lift. The pump will shift speed as necessary based on pressure.
The 2 stage pump definitely has a speed advantage in the extend mode. Most people do not have wood that is always tough to split.
/ Splitter Build Begins #10
The 3060 valve is designed for single stage pumps with relatively low flow rates. It adds the return fluid to the volume going to the extend side of the cylinder. They list it as boosting the speed by a factor of six times, or 4 gpm turns into 24 gpm, although how they arrive at that number escapes me.
You hold it in one position until the splitter starts to labour, then move it one notch further to eliminate the multiplying device and just get normal flow to finish the split. Return is auto kick-off at the end of stroke.
How much extra heat this valve creates is a debatable question. I've never seen one, although there's been lots of talk. If it were me, I'd talk with Prince's customer service folks and ask that question. I'll probably buy one myself in a couple years, since the hyd flow on my Kubota would make for slow splitting otherwise.
Sean
OK now I understand the way the valve works. Very good idea. But now I have another question about the 2 stage pump and you may have answered my question an I just can't see the forest for the trees. Does the two stage pump still work the same way in retract. Will i get 28 with no load or will I only get the 6.5 gpm that all the 2 stage pumps i have found list as stage 2 gpm?
I have got the engine now its a 16.5 BS and I have been looking at a Hadex 2 stage pump that is only $179 28/6.5.
/ Splitter Build Begins #12
It is 28 GPM up to ~650PSI. The PSI is determined by the resistance the cylinder sees. Anything that requires more than 650PSI of force would kick it to the second stage @ 6.5GPM.
So on retract, it would be fast. On extend, it would also be fast until it needed more than 650 PSI of force. Which with a 5" cylinder, would be about 6 Tons. So if a peice of wood only takes 5 ton to split, you would never see it slow down. IF it needs more, it will slow down until the resistance is less than the 6 tons
Sean
The 3060 that I just got and hooked to the 3pt splitter does make for a very nice extend stroke less than half the same time with out the 3060. But it only has that effect in extend which leaves one watching with lust in the heart for a retract as fast. On a good note how ever I noticed that if I gave the cylinder about 2 seconds in fast mode the pieces would bust 75% of the time without changing to power side an this was on a 3.5 bore x 1.5 shaft cylinder might bust all with a 4x2. I believe if the lower gpm is your only option its worth the money because any improvement beats no improvement. But if you can get a higher gpm pump I think that may be the better purchase. Or I hope so cause I am about to find out.
PS. Dear Santa please send the fine folks at Prince a new design for a fast extend/retract detent with lower gpm power side valve.
/ Splitter Build Begins #14
If I have the same Princes pump you are talking about it goes on the power take off and is set up for my 1529 MF tractor 28 hp. On idle it splits faster than I can chunk wood to it. When talking about speed what kind of set up does a person need for a 4 and 5 sec split and return I don't think 2 of us could keep up that pace very long. But what do I know. Has to be a big person to throw a 50 to 300 lb chunk every 4 to 5 sec for 6 to 7 hours a day. Woo heck of a man.
/ Splitter Build Begins #15
As for suggestions, a log lift combined with an extension table (assuming fixed wedge design) takes lots of grunt out. I've never had a boom or winch, but picture the walk out/attach tongs/walk back/activate winch/juggle log into position/detatch tongs/swing away as being time consuming. Of course the whole time you're thinking about how it doesn't hurt your back, so there's compensation...
The log lift still requires you to roll the rounds to the lift, so you still get a workout, but the lifting is easy and the log presented to the wedge lined up. Maybe add a small sloped table on the operator side to help corral splits.
Also never had a wedge lift but it is appealing.
Jim
Jim
That is exactly what kind of comments I am looking for. Apples to Apples comparison, pros and cons of designs and trying to figure what is the best design for a splitter. I think that the log lift would be more efficiant not to mention safer than the winch crane so that being said I think we will go with the lift. And I agree a log corral and table to catch splits is needed. I saw a video of a timberwolfe splitter with a manually operated log lift with a lever that hooked on a catch of some sort to hold it in position. Anyone familiar with that and does it work well.
/ Splitter Build Begins #17
You were asking about the single stage 22 GPM pump.
Perhaps you don't realize that a 22 GPM single stage pump at a pressure of 3000 would need 45 HP, where as, the 22 GPM pump at 650 psi only requires about 10 HP, and if you raised the cut in pressure to 900 psi the 7 GPM at 3000 psi would need about 14 HP
The only way you could use the 22 GPM single stage pump is with a tractor with a 45 HP PTO to drive the pump at an rpm of 3600 rpm, or a stand alone 45 HP engine with the single stage pump coupled to it.
/ Splitter Build Begins #18
You said that you have a trailer you're scrapping to build the splitter. You might consider leaving the springs and lights in place so that you can tow the splitter on-road easier. Others may need to chime in on this question: If a logsplitter has springs under it do you need stabilizers to take the sway out of it while it's running?
Also consider a 4-way wedge. Twice the splits in the same amount of time.
/ Splitter Build Begins #19
Jim
Some of my logs go from 500 to 800 after getting them on the table split a 600 lb log you got 2 300 now the winch gets half of it out of the way get half on the table the other half on the winch chop off pieces. I have splitt two chunks loose they fill a ranger pickup truck over full. So man handling is out of the question. I have MF 1529 some of my chunks make it light with a 600 lb sputter on the back. The tractor will pickup 1100 lb guess that weight. Later
/ Splitter Build Begins #20
What is the GPM of your PTO pump, and the model #? Is it a 540 or 1000 PTO rpm speed.
1985 Mack RW713 Superliner Tri-Axle Heavy Haul Truck, VIN # 1M2AY11Y6FM001206 (A61165)
1985 Mack RW713...
KUBOTA LA354 FRT LOADER ATTACHMENT (A62130)
KUBOTA LA354 FRT...
UNUSED INDUSTRIAS AMERICA 82R FEEDER WAGON (A62130)
UNUSED INDUSTRIAS...
Black Jet Dock Drive-On (A59228)
Black Jet Dock...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
2008 International 4300 Altec LRV60-E70 70ft Forestry Bucket Truck (A61568)
2008 International...
