4540 Oil filter issue
/ 4540 Oil filter issue #1
BigBoyinMS
Central Mississippi
'73 MF135 & Montana 4540
What brand and part# oil filters does everyone use? I changed oil a while back and the Carquest filter that came off and the new Wix 51064 that I put back on are made where only about 1 turn (if that) of the threads catch. In fact, I had to push the filter to compress the gasket to get it to catch. Is anyone else seeing this? Or is everyone buying filters from LS?
So far the WIX is holding. I've got about 10-12 hours on it since then.
/ 4540 Oil filter issue #2
Without trying to be TOO smartA$$ about it.
Any chance you left the old gasket on ?
It is SO easy to do, especially with a first filter removal; a) You aren't used to THAT engine b) often times the filter and especially the gasket paint glued on.
With most of the cars/trucks that I have caught my kids doing this with it has led to MASSIVE oil leaks, but I can see it sealing pretty well in some cases.
That is a common problem but I checked to be sure. I did find a thread from 2005 or 2006 talking about the same issue but never saw a definite answer.
/ 4540 Oil filter issue #4
Mitsubishi, Yanmar, or Subaru engine ?
Whichever it is, get the molded in the block engine model number and back reference that.
Don't wanna scare Ya, but a lot of spin on filter heads are female threaded.
The male that you screw the filter onto is basically a pipe nipple (double ended male).
Some half wit could have used an unusually short one on your engine (-:
I would get the vernier out and see how much thread is actually exposed, compare that to whatever car/truck you change the oil on next.
I believe in 3 turns, but that is mostly faith based - based on other engineering.
It has the Mitsubishi S4QS.
You have me thinking now. I have to make a parts order sometime and I think I'll order a new factory nipple to compare. I think I'll also look for a nipple with a little extra length but it's an M20 diameter x 1.5mm thread so that may not be an option.
With some of the boneheaded things I have found that the previous owner did I would not doubt it isn't the factory installed nipple.
/ 4540 Oil filter issue #6
It COULD happen that such a nipple would get stuck in the filter and be discarded with the filter.
Yeah, I know, I know, they are supposedly staked in, or at least thread locked (loctite'd) in, but could happen.
I would be very Leary of a strategy to use a longer nipple.
If it projects too far into the filter it could cause internal damage, resulting in total internal by-pass. If it merely stops the filter from getting on far enough to compress the gasket, at least you'll know about that fairly quickly (-:
Information nobody asked for (in this thread);
Not knowing which other engines have been used in Montana tractors, or who contract built them, the Kukje HRA1102000A3 filter supposedly cross references to an STP 52808.
This is used on the Kukje built, Cummins designed 4 cyl diesel.
They claim to actually BUILD that engine under patent license from Cummins and their tractors have been painted to order for several OEM brands, including JD.
/ 4540 Oil filter issue #9
I have an 06 4940C with Misubishi engine.
I"ve been using the WIX filter on it all the time. Mine seems to thread on with about three threads as mentioned earlier.
I"m pretty happy with the WIX filter. I also run synthetic in mine. I posted this quite a while back and I'm really happy with the performance I get with the synthetic. Especially with the hot summers we get down here. The engine runs much cooler.
Cheers.
/ 4540 Oil filter issue #10
I think the Mitsu S4S is the same engine as we had in our 5740C. I used a NAPA gold 7106 and it seemed to fit properly. I think I remember somewhere about some filters not having enough thread, not truly a nipple issue? Can't find it now.
Brent
/ 4540 Oil filter issue #11
There are spec tables for all this, I find it hard to believe that oil filter selection is critical.
Seems you need to match a) thread b) gasket diameter and width - that would just be enough to get it on there and not leak.
c) flow capacity - I doubt a slow revving tractor circulates oil much faster or at a significantly higher pressure than most cars
d) by-pass valve relief pressure (if applicable)
e) filter screen size - I mean particle size screened out. This may be a trade off with c) above.
I doubt that it really matters THAT much.
Sure, 10 microns may be better than 20, 5 may be better than 10, but I would take it on faith that whatever is on the shelf as a generic car/truck oil filter probably stops small enough particles.
Personally I think if the thread is right and the gasket matches its good enough.
The other parameters aren't going to cause oil starvation or a seized engine.
Option B
For anyone REALLY worried about this get a remote oil filter set up from a speed shop.
That would allow you to mount whatever size & spec filter you want (somewhere) just choose
the right head.
2021 Ford Explorer AWD SUV (A61574)
2021 Ford Explorer...
2020 John Deere HPX615E Gator 4x4 Diesel Utility Cart (A61572)
2020 John Deere...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2016 PETERBILT 579 (A63569)
2016 PETERBILT 579...
