TC40DA Glow Plug Timer
   / TC40DA Glow Plug Timer #1
DiverDarrell
Member
My timer stopped working, after researching on here that it would need to be replaced, i decided what the heck and tore it apart to see what made it tick. to my surprise i found a broken solder joint, a quick easy fix in the long run.
   / TC40DA Glow Plug Timer #2
It pays to be inquisitive, glad you saved some money.
   / TC40DA Glow Plug Timer #3
That's pretty neat! I saved my old timer, so maybe I need to do some experimenting also. My timer was coming on and going off at odd times, so it probably was not a broken wire, but you just never know since it could have been making intermittent contact due to vibration. For the price we pay for these things, you'd think they would be bulletproof, but the only thing that's bulletproof seems to be the profit margin. New Holland's price is nearly $70, but you can buy the timer on eBay for $13.95 with shipping included. Sure sounds like a New Holland profit center to me.:mad:
   / TC40DA Glow Plug Timer #4
My timer was doing the same thing as Jinman's. I hooked up a test light and jiggled some components until I found the one with the bad solder joint. That was 2 or 3 years ago, been fine since.
   / TC40DA Glow Plug Timer #5
Had the same problem, but after replacing three breakers one at a time I decovered it was was caused by the wiring harness. It was routed in such a manner that when the side pannel was installed and pressure was applied to line up the bolt holes it put pressure on a breaker causeing the problem. Now I have three new breakers, maybe I will need them in the future.
   / TC40DA Glow Plug Timer #6
Do you mean relays instead of breakers? The fuses and a single breaker are under the instrument panel and never come in contact with the side covers. Unless you are talking about something other than a TC40DA tractor, there are no breakers anywhere else. However, all the relays and safety modules are located under the left-side cowling panel.
2019 GENIE Z-45/25XC V2 TELESCOPIC MANLIFT (A51242)
2019 GENIE...
2016 CATERPILLAR CT660 TRI AXLE DUMP TRUCK (A51222)
2016 CATERPILLAR...
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
