Honda TRX300 no power to switch
   / Honda TRX300 no power to switch #11
Here are the parts that I found for a year 2000 with model of TRX300.
1. Battery # YTX14-BS
2. Spark plug - I could not find one in the parts breakdown, its commonly a NGK DPR8EA-9 IIRC.
3. Air filter # 17254-HC5-900
4. Oil Filter # 15412-HM5-A10
5. Oil # 10W-40, whatever brand you like the best.
Let me know if you have any questions about servicing, but the service manual should detail the tune-up procedure quite nicely. Change the oil after you warm it up, and make sure you change the plug when the engine is cold. When you install the new air filter, soak it in air filter oil, and squeeze out the excess. When you change the oil filter, be aware which direction that the rubber seal faces when you pull the cover off.
Thanks for your help. I will probably get a new solenoid as well, and fuses based on what I see.
Well, I ordered the parts, and used the kick start for awhile. Then it died with me again and I could not get it to start with kick. The spark plug, which was new, was toast. Yesterday, the parts came. I replace solonoid, fuses, and battery, and cleaned the area real good.
The green neutral lights are back on, but would not start. I went for a new spark plug, but cannot get it to crank. Almost like it is not getting gas, but I am a novice in this stuff.
I have pushed it on my trailer to take to the shop.
Thanks for your help. I think I have the electrical fixed.
Ignition Controller Module........Honda is proud of that part, and labor costs a bit to find the problem. Seems Honda's manual has about 18 things to check before you get to this module. Cost a bit but I am glad to have my 4-wheeler back home and working.
I have really enjoyed having my 4 wheeler back. It is like a friend.
Now I have a new problem to tackle. Yesterday, the brake cable to the left handle bar broke. Anyone have experience putting on a new one?
Well I think my friend the trx300 is dead. Since the start of this thread I have had two more controllers replaced and now the. Ontroller and regulator have blown. I have spent too much on it already so ready to sell for parts and get something to replace it
What are options for getting some cash for the honda?
What atv rtv or utv do you recommend for replacement?
   / Honda TRX300 no power to switch #17
Wow,
Def have some electrical going heywire. Hopefully any mods that were done to it were taken off for troubleshooting. Sounds like a ground or stator problem to me. As for a replacement-its hard to recomend what because of personal preference.
9000 (A47477)
9000 (A47477)
2006 MAC TRI AXLE 37 X 102 DUMP TRAILER (A58018)
2006 MAC TRI AXLE...
2001 FREIGHTLINER FL70 (A58214)
2001 FREIGHTLINER...
2018 NISSAN Sentra (A56859)
2018 NISSAN Sentra...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2015 INTERNATIONAL FLATBED (A58214)
2015 INTERNATIONAL...
