small Skid Steer. belt drive--version
/ small Skid Steer. belt drive--version #1
Pooper
Kentucky
I finally decided to build a skid steer type design, I've spend months hanging out in a scaled tank site and got the idea of how to build a belt driven transmission that will run a small skid steer vehicle, not for real work but - to just be building it. lol I bought a mig gaseless welder, & I ordered lotts of parts, a 6.5 engine. pulleys. sprockets, chain & Tires, pillow block bearings, axles..and angle iron ectt..and drill bits, lol so here i go. I'm taking pics and will upload them .
/ small Skid Steer. belt drive--version #2
Will your belt transmission be similar to what the Struck Mini dozers have?
few changes but basically works the same.
some pics, more to come.
The belt transmission drive unit is in a wood frame right now I'll move it to a metal frame when i mount in in the skid steer frame. I still have more parts to buy, more nuts and bolts, the belts for the pulleys, metal to build the sides, the load arms. and bucket. and cab, seat, ectt , i need a small hydraulic unit to raise and lower./tilt/ scoop the bucket. cylinders, ectt , hoses, control levers, fittings. lol i may change the belt drive to hydraulic later. it's fun to just build the thing lol
/ small Skid Steer. belt drive--version #6
It looks good, one concern is the frame not being heavy enough, i'm not sure what you're gonna do with it, but i would build the frame out of square tubing or at least channel. I'm afraid your frame is gonna twist like krazy, i'm just going with my gut reaction on this, i may be wrong. I like the build, can't wait to see your progress.
I agree, I will get 2 x 4" x 1/4" rectangular tubing and re do the frame.(welded ) the 1 1/2 x 1 1/2 1/8" angle iron is too weak. ( as you can look closer the frame is bolted together ) it is a test frame to make sure it will drive ( work )
/ small Skid Steer. belt drive--version #8
Whew! I was afraid you may get mad, i was only trying to help. 1/4" tubing will be a lot better. Can't wait to see what its gonna look like.
Metal close to this.
I appreciate and want advice, it's part of the process of building. helping each other with fresh and better ideas. :)
/ small Skid Steer. belt drive--version #11
Hey, i just noticed you're from ky. What part of the state are you in?
South of Danville
/ small Skid Steer. belt drive--version #14
I'm in Mt.Sterling, maybe i'll get to see this machine first hand.
That sounds good, i been buying parts since i joined this site so maybe at the end 2012 i'll have it finished. lol:laughing:
/ small Skid Steer. belt drive--version #16
Have you built anything before this? Looks like a fun project.
few years ago I build a 45" x 6' utility trailor, bought the axle fron TSC and got the metal from metals depot, used treated deck boards on the floor put 2 2x6 for the sides it looks good. I'm a mad scientist/cobbler lol
/ small Skid Steer. belt drive--version #18
Have any pics of it? I cut this trailer of mine into and extended it 2 feet to make it a 16 footer. I've never built one from scratch though.
here it is, it's just big enough to haul a 250 4 wheeler or a 38" Bolens riding mower.
/ small Skid Steer. belt drive--version #20
Hey, that looks good, bet the 4-wheeler fills it up nicely. You seem to have a good eye for building. Take advantage of all the talented people on TBN, they will do you proud.
