Dead Battery - BX25
/ Dead Battery - BX25 #21
If you do not have a multimeter, mention to the folks that it would make a good Christmas gift. A decent digital one can be bought for about $50. I personally like analog better, but they are harder to find and less fool proof to use. Learning to use a multimeter can be a good diagnostic tool.
A 1st step on checking a battery with a multimeter is to measure the voltage with the engine off. It should read about 12.5 volt. After you start the tractor, it should read about 14 volts. That tells you that the alternator is running. If it doesn't read more voltage with the engine running, it can't be charging. If the engine is on and you turn the lights on, you should see a little dip in the voltage, but it should come back up again.
When you have problems like that, it is also a good time to check the connectors. Are they clean and tight. You can get a little wire brush to clean the insides of the connectors and the terminals on the battery. Spraying a little WD40 on them once and a while will help keep down corrosion.
If you go long periods without using it, you might want to get a battery charger with a float function. I have several "Battery Tenders", mostly for the motorcycles, but I also put one on the garden tractor when I put it up for the winter. I put one on the Kubota during the winter if I haven't used it for a few weeks or sometimes just before they are predicting snow to make sure the battery is topped up for a cold start the next morning. A float function allows you to leave it on the battery without over charging it. It will charge the battery, then stop and until it reads that it needs to charge again. A regular charger will overcharge the battery unless you take it off.
Maybe this was just a weak battery from the start, but learning to do a little troubleshooting will be a great help for you down the road. If you go to one of the big book stores or good old Amazon, you can find one of those "Dummies" series books for learning basic electricity. Those books are easy to read and understand without bogging you down in a bunch of theory.
Well, unfortunately the same thing happened all over again today...ugh...:mad::mad::mad:
BX went off to the dealer today. Hopefully they will find the problem, and it will be covered under warranty...
/ Dead Battery - BX25 #24
Good luck! Must be exasperating to have a new tractor that doesn't work....:mad: Hope the dealer figures it out.
Thanks, at least there have not been that many problems with the tractor so far...also, it is not that "new" at 200 hours. ;)
/ Dead Battery - BX25 #26
"also, it is not that "new" at 200 hours."
.... Just getting broken in! :) (Mine now has 280)
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A63688)
FRESHLY...
2017 Hyundai Trailer (A62613)
2017 Hyundai...
2018 John Deere 3033R (A64126)
2018 John Deere...
2018 Holbart 210 MVP Mig Welder (A64194)
2018 Holbart 210...
2014 UTILITY 53X102 DRY VAN TRAILER (A59914)
2014 UTILITY...
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
