Looking for salvage part, Ford 4000
/ Looking for salvage part, Ford 4000 #1
iafarmgal
Ford 4000 4cyl.
Hi, I'm looking for a salvage part for a 4 cyl. Ford 4000, dual clutch, 5 speed. I'm just the "dummy" doing the computer work so excuse my ignorance! (The real mechanic is doing the work on the tractor but he's unable to locate this part.) Best I can tell this part goes by the title "clutch release arm", "shift fork", or "clutch fork". Any suggestions anyone???
/ Looking for salvage part, Ford 4000 #2
1st, welcome to tbn.
2nd, to make sure there is no confusion, your mechanic really should be referencing items by numbers found inthe parts catalog, just to ensure the correct part is actually ordered.
in this post I'm including a parts list and a pic for the 5spd case and forks, in the next message I'll include a listing for the gears.. etc.
I'll be back in the third message and check a few places I know of that sell parts to see if there is anything on the use dmarket that 'I' know of.
soundguy
1 1 NLS No Longer Serviced Transmission Assy., L/Gear Shift Cover, 9' Double Clutch, ASN 14256 {310872}, Start Year: 01/01/1958
1A 1 NDA7005B Case Assy., Transmission W/Brake Shaft Thru Transmission, Before S/N 14257, No Longer Serviced, Years: 01/01/1955-12/31/1957
1A 1 NLS No Longer Serviced Case Assy., Transmission W/Brake Shaft, Under Center Housing, After S/N 14256 {310836}, Start Year: 01/01/1958
1B 2 NDA7508A BUSHING Bushing, Cross Shaft, Start Year: 01/01/1955
AR PL PROCURE LOCALLY Nut, Hex, 7/16"-14
2 PL PROCURE LOCALLY Bolt, 7/16"-14 x 1.38, Years: 01/01/1955-12/31/1957
AR PL PROCURE LOCALLY Washer, Flat, 7/16"
AR PL PROCURE LOCALLY Bolt, 7/16"-14 x 1.38
AR PL PROCURE LOCALLY Nut, Hex, 5/8"-18
2 PL PROCURE LOCALLY Bolt, 5/8"-18 x 3.12, Start Year: 01/01/1955
1 PL PROCURE LOCALLY Bolt, Hex, 7/16"-14 x 1", Start Year: 01/01/1955
4 PL PROCURE LOCALLY Bolt, 7/16"-14 x 1.50, Start Year: 01/01/1955
2 PL PROCURE LOCALLY Bolt, HH, 7/16"-14 x 1.94, Start Year: 01/01/1955
2 73279S PIN Pin, Dowel, 3/8" x .75, No Longer Serviced, Start Year: 01/01/1955
1 PL PROCURE LOCALLY Pin, Cotter, 7/32" x 1, Start Year: 01/01/1955
3 74116S PLUG Plug, Expansion, 15/16", Start Year: 01/01/1955
2 1 NLS No Longer Serviced Plate, Engine Rear Cover, 1/4" Thick, 4000 Row Crop Only {310836}, Years: 01/01/1955-12/31/1957
2 1 310741 Plate, Engine Rear Cover, 1/8" Thick, All Purpose Only, No Longer Serviced, Start Year: 01/01/1958
2 1 NLS No Longer Serviced Plate, Engine Rear Cover, 1/4" Thick, 4000 Row Crop Only {310767}, Start Year: 01/01/1958
3 1 NCA7306A Cover, Transmission Vase Front Lower, No Longer Serviced, Start Year: 01/01/1955
4 1 14457281 O-RING O-Ring, -114, Cl 7, .612" ID x .103" Thk, Start Year: 01/01/1955
5 1 87055S92 O-RING O-Ring, 1.125" ID x .139" Thk, Start Year: 01/01/1955
6 1 NCA7518A Cover, Transmission Inspection Hole, No Longer Serviced, Start Year: 01/01/1955
7 4 PL PROCURE LOCALLY Bolt, HH, 5/16"-18 x 5/8", Start Year: 01/01/1955
8 AR PL PROCURE LOCALLY Pin, Cotter, 5/32"x 1"
9 2 NLS No Longer Serviced Plug, Square Hd., 1/4"-14 {87604S}, Start Year: 01/01/1955
10 4 NDA7233A PLUNGER Plunger, Transmission Gear Shifter Interlock, Start Year: 01/01/1955
11 4 83407013 SPRING Spring, Transmission Gera Shift Rail, Start Year: 01/01/1955
12 1 E5NN7Z307AA GASKET O-Ring, Pressure Tube Between Center Housing & Transmission Case, Start Year: 01/01/1955
13 4 747238 PLUG
14 1 NDA7240A Rail, Transmission 1st & 2nd Gear Shifter, No Longer Serviced, Start Year: 01/01/1955
15 1 NDA7241A Rail, Transmission 4th & 5th Gear Shifter, No Longer Serviced, Start Year: 01/01/1955
16 1 NDA7242A Rail, Transmission 3rd & Reverse Gear Shifter, No Longer Serviced, Start Year: 01/01/1955
17 2 PL PROCURE LOCALLY Pin, Dowel, 1/4" x 1/2", Start Year: 01/01/1955
18 1 B9NN16A795A GASKET Gasket, No Longer Serviced, Start Year: 01/01/1955
19 1 NDA7723C BRACKET Bracket, Transmission Reverse Idler Gear, No Longer Serviced, Start Year: 01/01/1955
20 AR PL PROCURE LOCALLY Washer, Lock, 7/16"
21 AR PL PROCURE LOCALLY Nut, Hex, 7/16"-20
22 6 PL PROCURE LOCALLY Bolt, Self-Locking, 7/16"-14 x 1", Start Year: 01/01/1955
23 2 186397 Pin, Transmission Reverse Idler Gear Bracket Dowel, No Longer Serviced, Start Year: 01/01/1955
24 1 14466080 O-RING O-Ring, 3.984" ID x .139" Thk, Bracket Transmission Case, Start Year: 01/01/1955
25 1 NDA7141A GEAR Gear & Bushing Assy., Transmission Reverse Idler, No Longer Serviced, Start Year: 01/01/1955
26 1 NDA7140A SHAFT Shaft, Transmission Reverse Idler Gear, Start Year: 01/01/1955
27 1 NDA7143A BRONZE BUSHING Bushing, Reverse Idler Gear, Start Year: 01/01/1955
28 1 NDA7149A WASHER Washer, Transmission Reverse Idler Thrust, Front, Start Year: 01/01/1955
29 1 NDA7029A THRUST WASHER Washer, Transmission Reverse Idler Thrust, Rear, No Longer Serviced, Start Year: 01/01/1955
30 5 8N7245 SCREW Screw, Transmission Frok Lock, Start Year: 01/01/1955
31 5 PL PROCURE LOCALLY Nut, Hex, 3/8"-24, Start Year: 01/01/1955
32 1 NDA7230C FORK Fork, Transmission 4th & 5th Gear Shifter, No Longer Serviced, Start Year: 01/01/1955
33 1 PL PROCURE LOCALLY Screw, 3/8"-24 x 2.04, Start Year: 01/01/1955
34 1 NDA7231B Fork, Transmission Low & 2nd Gear Shifter, No Longer Serviced, Start Year: 01/01/1955
35 1 NDA7289B FORK Fork, Transmission 3rd & Reverse Gear Shifter, No Longer Serviced, Start Year: 01/01/1955
36 1 NDA7279B Gate, Transmission Gear Shifter Low & 2nd, No Longer Serviced, Start Year: 01/01/1955
37 1 NDA7411B Gate, Transmission 3rd & Reverse Shifter Shaft, No Longer Serviced, Start Year: 01/01/1955
38 1 NDA7229D LOCK Lock, Interlock, Gear Shift, Start Year: 01/01/1955
39 1 NDA7212A SHAFT Shaft, Transmission Gear Shift, No Longer Serviced, Start Year: 01/01/1955
40 1 NDA7223A GASKET Gasket, Gear Shift Cover, Start Year: 01/01/1955
41 1 NDA7211B Cover Assy., Transmission, No Longer Serviced, Start Year: 01/01/1955
42 10 PL PROCURE LOCALLY Bolt, HH, 3/8"-16 x 3/4", Start Year: 01/01/1955
43 1 8N11500 IGNITION SWITCH Switch Assy., Starter Push, Start Year: 01/01/1955
44 1 8N11529 GASKET Gasket, Starter Switch, Start Year: 01/01/1955
45 AR PL PROCURE LOCALLY Washer, Lock, 3/4"
46 1 PL PROCURE LOCALLY Nut, Hex, 3/4"-16, Start Year: 01/01/1955
1 PL PROCURE LOCALLY Screw & Washer, #8-32 x .25 Round Hd., Start Year: 01/01/1955
47 1 9N7010 PLUG Plug or Cap, Transmission Filler, Start Year: 01/01/1955
48 1 8N7011 GASKET Seal, Gear Shift Lever, Start Year: 01/01/1955
49 1 C5NN7277C SEAL Seal, Gear Shift Lever, Replaces P/N C0NN7277A, Start Year: 01/01/1955
50 1 NDA7202A Lever, Gear Shift, No Longer Serviced, Start Year: 01/01/1955
51 1 PL PROCURE LOCALLY Key, Woodruff, 1/8" x 5/8", Start Year: 01/01/1955
52 AR PL PROCURE LOCALLY Washer, Flat, 3/8"
53 AR PL PROCURE LOCALLY Washer, Internal Tooth, 3/8"
54 1 PL PROCURE LOCALLY Nut, Blind, 3/8"-24, Start Year: 01/01/1955
55 1 83905584 BALL Ball Assy., Transmission Gear Shift Lever, Start Year: 01/01/1955
56 1 NLS No Longer Serviced Rod, Interlock, Gear Shift {NDA77213A}, Start Year: 01/01/1955
57 1 NDA7227A Spring, Gear Shift Lever, No Longer Serviced, Start Year: 01/01/1955
58 1 NDA7288A Seal Assy., Transmission Shifter Shaft Only, No Longer Serviced, Start Year: 01/01/1955
/ Looking for salvage part, Ford 4000 #3
13 4 747238 PLUG
/ Looking for salvage part, Ford 4000 #4
ok, i lied.. this 3rd message is of the dual clutch assy, if needed:
1 311435 KIT Clutch Assy., 9" Double, Start Year: 01/01/1955
AR PL PROCURE LOCALLY Washer, Lock, 5/16"
6 PL PROCURE LOCALLY Bolt, HH, 5/16"-18 x 1.38, Start Year: 01/01/1955
1 AR NDA7563B PLATE Plate & Cover Assy., Clutch Press
2 AR PL PROCURE LOCALLY Washer, Lock, 5/16"
3 6 354550S BOLT Bolt, HH, 5/16"-18 x .72, No Longer Serviced, Start Year: 01/01/1955
4 6 354518S SCREW Screw, HH, 5/16"-24 x .656, Start Year: 01/01/1955
5 12 NDA77649A Seat, Clutch Pressure Plate Spring Double, 9", No Longer Serviced, Start Year: 01/01/1955
6 12 354502S RETAINER Retainer, Clutch Pressure, Plate Spring & Seat, Start Year: 01/01/1955
7 4 C0NN7549B Facing, Clutch Disc, Double 9" & PTO Clutch, No Longer Serviced, Start Year: 01/01/1955
56 PL PROCURE LOCALLY Rivet, Facing Countersunk, Start Year: 01/01/1955
8 1 E8NN7550LA DISC Disc Assy., Clutch PTO Double 9", Replaces 311436, Start Year: 01/01/1955
9 12 311432 SPRING Spring, Clutch Pressure, Plate Double 9", Start Year: 01/01/1955
10 1 NDA77660B PLATE Plate Assy., Clutch Control Dr. Double, 9", Start Year: 01/01/1955
11 AR E8NN7550GA DISC Disc Assy., Clutch Double 9", 15 Splines, Heavy Duty, W/5-Speed Transmission, Start Year: 01/01/1955
11 1 E8NN7550GA DISC Disc Assy., Clutch Double 9", 15 Splines, Non-Asbestos, W/NDA7563B & 311435, Start Year: 01/01/1955
11 1 86640503 REMAN-CLUTCH DISC Disc Assy 9"; For N.A. only
11 1 86640504 CORE-CLUTCH DISC Return number - For N.A. only
12 1 311423 PLATE Plate Assy., Clutch Pressure, Double 9", Start Year: 01/01/1955
13 3 NDA77664A PIN Pin, Clutch Release Lever Strut Double 9", Start Year: 01/01/1955
14 3 PL PROCURE LOCALLY Pin, Cotter, 3/32" x 5/8", Start Year: 01/01/1955
1 86531345 HUB Hub, Clutch Release Bearing Double 9", 5-Speed Transmission, Before S/N 14257, W/NDA7580B, Replaces NDA7571C (Not Shown), Years: 01/01/1955-12/31/1957
1 86539876 HUB Hub, Clutch Release Bearing Double 9", 5-Speed Transmission, After S/N 14256, W/NDA7580B, Replaces 311260 (Not Shown), Start Year: 01/01/1958
1 NDA7580B BALL BEARING Bearing Assy., Clutch Release Double 9", 5-Speed Transmission (Not Shown), Start Year: 01/01/1955
/ Looking for salvage part, Ford 4000 #5
Soundguy, I would think, you have to move one module toward the engine. He is looking for a clutch related arm. I would guess, the arm, which engages with the throw-out bearing, however, I'm not familiar with a "dual clutch".
/ Looking for salvage part, Ford 4000 #6
this one probbaly has what part you are looking for as #16
1 1 NDA7506B SHAFT Shaft, Clutch Pedal, 5-Speed, No Longer Serviced, Start Year: 01/01/1958
1 1 311201 SHAFT Shaft, Clutch Pedal, 4-Speed, After S/N 14256, Start Year: 01/01/1958
2 1 NDA7526A BUSHING Bushing, Clutch Pedal, No Longer Serviced, Start Year: 01/01/1958
3 1 NDA7519C Pedal Assy., Clutch, No Longer Serviced, Start Year: 01/01/1958
4 1 PL PROCURE LOCALLY Fitting, Angle Lubrication, 1/8"-45, Start Year: 01/01/1958
5 AR PL PROCURE LOCALLY Washer, .880/.890 I.D. x 1.50 O.D., Start Year: 01/01/1958
6 2 137286 SNAP RING Ring, Snap, #87, Ext, Start Year: 01/01/1958
7 1 NDA7521B ROD Rod, Clutch Release, No Longer Serviced, Start Year: 01/01/1958
8 1 PL PROCURE LOCALLY Pin, Clevis, 3/8" x 1-5/16", Start Year: 01/01/1958
9 2 PL PROCURE LOCALLY Pin, Cotter, 1/8" x 5/8", Start Year: 01/01/1958
10 1 PL PROCURE LOCALLY Nut, Hex, 1/2"-20, Start Year: 01/01/1958
11 1 PL PROCURE LOCALLY Clevis, Adjusting, 1/2"-20, Start Year: 01/01/1958
12 1 PL PROCURE LOCALLY Pin, Clevis, 3/8" x 1-3/32", Start Year: 01/01/1958
13 1 311246 SHAFT Shaft, Clutch Release, 5 Speed Transmission, No Longer Serviced, Start Year: 01/01/1958
13 1 313557 SHAFT Shaft, Clutch Release, 4-Speed Transmission, No Longer Serviced, Start Year: 01/01/1958
14 1 PL PROCURE LOCALLY Screw, Set, Square Hd., 3/8"-16 x 1-1/4", Start Year: 01/01/1958
15 1 PL PROCURE LOCALLY Nut, Hex, Jam, 3/8"-16, Start Year: 01/01/1958
16 1 487515 FORK Fork, Clutch Release Shaft, 4-Speed, Start Year: 01/01/1958
16 1 311649 FORK Fork, Clutch Release, Shaft, 5-Speed, Start Year: 01/01/1958
17 AR PL PROCURE LOCALLY Pin, Flat Hd., 5/16" x 1-1/2", 4-Speed Only, Start Year: 01/01/1958
AR PL PROCURE LOCALLY Nut, Hex, 3/8"-24
1 PL PROCURE LOCALLY Bolt, Hex, 3/8"-24 x 2.12, 5-Speed Only, Start Year: 01/01/1958
/ Looking for salvage part, Ford 4000 #7
jumping the gun aren't ya a bit????
I'm uploading ALL of the related parts.. I'm not the 'flash' and don't have super speed, and work on a netbook with broadband internet access.
i'll let you handle it from here.
soundguy
Thanks Guys! I'll forward this on to the gentleman who is doing the work. He's torn this tractor down before and rebuilt some of the pieces but it's now so worn out that he can no longer do this. We have a service manual but the pic.s weren't all that helpful. I'll forward this all to him so he can have a go at it. I do appreciate all the info.. You guys are "Awesome Possum!"
