Share One Safety Tip
/ Share One Safety Tip #1
MichKubota
Holly, MI
Kubota L2850 Hydrostatic/ Deere 5410 w/loader
Thought I would start this thread to see if anyone else has safety tip they care to share.
Here is mine - When getting off a tractor with engine running, make sure shuttle shifter is in neutral and shuttle mechanical safety interlock has shuttle LOCKED in neutral and emergency brake is ON. Don't think I need to explain why this is important but I will anyway. If shuttle interlock is not used, it is too easy to accidentally bump the shuttle shifter and shift forward or reverse when mounting or dismounting tractor. You may then possibly run yourself or someone else over with tractor.
/ Share One Safety Tip #2
If you park your tractor on muddy ground and it freezes overnight, it's possible for you wheels to freeze to the ground. Pulling out in the forward direction can cause the tractor to flip over backwards.
So either always start out in reverse or park you tractor facing a tree or wall so you will back outand avoid a back flip.
/ Share One Safety Tip #4
Whats a "shuttle mechanical safety interlock"? I don't think my L4200GST has one of those.
Safety tip: When operating near a structure, make sure no-one is in standing front of the barn, should one accidentally stuff their backhoe bucket/dipper through the front wall of the barn while backing up. That one is particularly fresh in my mind for some reason...
JayC
/ Share One Safety Tip #6
Never operate a tractor within sight of someone to whom you are very attracted.
/ Share One Safety Tip #7
When telling your wife you want to buy a new attachment for your tractor, be prepared to duck and do not break her the news in the kitchen where she has access to knives. :D
My safety tip of the day.
/ Share One Safety Tip #8
Make sure everyone understands that they are not to approach you on any piece of equipment until they have made eye contact with you and you have indicated that you see them and they may come closer.
/ Share One Safety Tip #9
heres the biggest safty tip of all,because i know a few that has done this.when getting off the tractor always make sure your britches leggs do not get hung on the clutch pedal.or youll flipp off the tractor.i know some that flipped off their tractors like that.
/ Share One Safety Tip #10
always use 4wd and lowest gear when mowing hills - and mow up and down.
/ Share One Safety Tip #11
Keep your bucket as low as practical for the conditions.
When using FEL, use proper ballast.
OK, that was two.
/ Share One Safety Tip #12
Do not hook or un-hook the PTO shaft with the engine running. :thumbsup: :laughing:
/ Share One Safety Tip #13
don't urinate on an electric fence?
um.. :)
ok.. here's one.. if you have seperate R & L brake pedals that have a interlock, make sure you lock them vefore roading your tractor.
soundguy
/ Share One Safety Tip #14
or if you followed that 'other thread'.. more importantly.. don't hook or unhook the pto shaft while the pto shaft was moving.. cuz apparrently that's what some guys were doing.. grabbing spinning shafts and then wondering why they got hurt... :(
soundguy
/ Share One Safety Tip #17
my fel is practically a 'man lift' when i need stuff up high.. :)
/ Share One Safety Tip #18
I know what you gents mean,but I've seen people being hauled in FEL/Buckets(pics even here) or in parades that the wisdom behind it seemed senseless to say the least.
I'am sorry does'nt cut it after damage is done. :(
Boone
/ Share One Safety Tip #19
Boone
As a transport, I would agree with you. The FEL is not the right tool. As a ladder, the FEL is perfect. There is some movement associated with it being a ladder, but the main purpose is not the movement itself. And I don't know about anybody else, but when I move it, it takes seconds to count the wheel revolutions and is done at considerably less than full height.
/ Share One Safety Tip #20
Made a platform for mine I used for hanging soffit, painting gutters and what not have a long stick and wire the lever to raise and lower, maybe not the safest, but I do wear a hard hat and safety glasses:laughing:
2013 Mercedes-Benz GL450 AWD SUV (A61574)
2013 Mercedes-Benz...
2018 Ford F-350 Crew Cab Landscape Dump Truck (A61573)
2018 Ford F-350...
Katolight SED60FJJ4 75kVA Towable Diesel Generator (A61572)
Katolight...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
2014 Jeep Grand Cherokee 4X4 SUV (A61574)
2014 Jeep Grand...
