Backhoe John Deere 8a what does it fit?
/ John Deere 8a what does it fit? #1
Tubecat
I have a 1992 John Deere 8a backhoe installed on a 2 wheel drive 39 horse 1992 John Deere 1070 tractor. I wanted a subframe backhoe and had a budget so I found this one. The 1070 is the size I need but i should have held out for a 4 wheel driver tractor. Now i'm thinking i could look for another John Deere 4 WD tractor to install the 8a hoe onto. However, I'm not sure what tractors i should look for and are compatible. Any help or ideas would be greatly appreciated. thanks
/ John Deere 8a what does it fit? #2
The directly compatible tractors would be a 4wd 1070, 990, or 4005. JD also used a hoe about that size on the 5000 series in the 90's IIRC, not sure if it was the 8a or something else though. Regardless the subframe will only fit the yanmar based tractors (1070, 990, 4005) so that's where I'd start looking.
thanks. what do you think about a 3005 or a 790 or 955?
/ John Deere 8a what does it fit? #4
Too big for any of them...
We had a TBNer who built or modified a subframe and installed an 8A loader on a Deere 4200...which means you could do the same on a 4300, 4400, 4310 or 4410. IIRC, it came off a 970.
The TBNer's nick is Arrabil. He hasn't posted in a year or more, but if you search using his nick, I'm sure you'll find the thread on how he did the job.
Thanks. I found the thread, it was very cool, smart guy. This defiitely reassured me that I want a subframe hoe. Probably a little more technical than I could get into though. I see an 850 4 WD that the delaer says 28HP and but the "tractordata.com" website says 22 HP so I'm confused. The same site says that the 850 uses an 8a hoe. I'm wondering if the subframe, power assist hydraulics etc would all work and if this tractor is really 28 HP? if anyone has any insight that would be great. thanks to all that have helped so far.
/ John Deere 8a what does it fit? #6
The dealer is probably giving you the gross engine HP (always higher then the PTO HP). The PTO HP is (IMHO) a better method of expressing a tractor's usable power. An example is my Deere 4400: 35 Gross Engine HP, 30 PTO HP for a gear transmission tractor. The HST model is a little less PTO HP.
Drawbar HP only really applies to larger utility tractor that draw (tow) ground engaging implements behind them.
/ John Deere 8a what does it fit? #7
Did you ever find out if an 8A will fit a JD850? I want to take an 8A off an 850 and put it on a 1070 but I don't know if the subframe will fit. Does anyone know?
/ John Deere 8a what does it fit? #8
i do believe that the 8a fits the 950 and the 850 both have light duty hydraulics,i have a 950 and was looking for an 8a and was told about the hydraulics.not to say that you would not enjoy the 8a hoe but for heavy work not so good.by the way my 950 is 27 hp.:thumbsup:
/ John Deere 8a what does it fit? #9
I have found an 8A that is on a JD850. I want to buy the 8A and put it on my 1070. I need to know if the subframe will fit my 1070. This would be my first backhoe so I'm not sure what fits what.
/ John Deere 8a what does it fit? #10
If it helps, My cousin has the 950 Deere 4x4 with the 8a hoe on it. Other than the weird linkage for the swing function,it has held up well.
/ John Deere 8a what does it fit? #11
I went and looked at the 850 but the subframe was different than the one I need. It looked like the subframe that came with the model 8 backhoe. Different mounts I guess for the smaller tractor.
/ John Deere 8a what does it fit? #12
Thanks for the responses. I ended up buying a used Woods BH9000 for the JD1070.
/ John Deere 8a what does it fit? #13
With slight modification, I have one on a Ford 1910 4 wheel. The tractor handles it well and I had a really low budget at the time. As a matter of fact, I'm looking for new swing chains for my 8a. Anybody now a good place to find some?
/ John Deere 8a what does it fit? #14
I'm glad you were able to make it fit. The Woods BH9000 that I bought came off a Ford 1920. I had to get a different subframe to fit my JD1070 so I still have the old one here to fit the Ford if anybody is looking for one.
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
429904 (A61165)
429904 (A61165)
BUYERS PREMIUM & PAYMENT TERMS (A59910)
BUYERS PREMIUM &...
KUBOTA KX057-4 EXCAVATOR (A62129)
KUBOTA KX057-4...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
02GER CHICKET HOUSER 240F (A62131)
02GER CHICKET...
