Kubota rtv1100 which plow?
   / Kubota rtv1100 which plow? #1
2009 kubota rtv
I plow my drive way and 2 commercial lots. Wondering if I should go with the kubota v blade or boss v blade? Any advice would be great. Thanks
   / Kubota rtv1100 which plow? #2
   / Kubota rtv1100 which plow? #3
TO use a Blizzard you would need to add a lift kit for ground clearance.
Are you recommending blizzard over the two I mentioned? If so why do you feel it's a better set up? I am looking to get the best in terms of quality. I'm not even sure the boss plow is rated as a commercial plow...
   / Kubota rtv1100 which plow? #5
I just installed a Boss V blade on my RTV1100, haven't plowed with it yet but I can assure you it is HEAVY DUTY, I would even say overkill, it's a very well built unit.
I'm going to try to get some pictures posted today.
   / Kubota rtv1100 which plow? #6
I don't believe Blizzard makes a V-plow. At least one that would work on an RTV/UTV. However, the Blizzard plows are very nice. If you decide to go with a straight blade, it's certainly worth considering.
Steve thats good to hear.. I'm looking for something heavy duty. Pics would be great to see.
   / Kubota rtv1100 which plow? #8
I just got a RTV 1100 with the Kubota straight plow with hyd. angle. Looks useless to me. I am gonna sell it off. Unless you only plow 1 little drive, I think I would beat it to death rather soon.
   / Kubota rtv1100 which plow? #9
I've been using mine for 2 years to plow a 700ft rightaway and 9 100+ ft driveways...It works good...The only thing I'm not thrilled with is the electric lift actuator..
   / Kubota rtv1100 which plow? #10
Not sure of a v plow by blizzard but we have had to add lift kits to get there frame off the ground on there straght blades. The RTV will push full blades with no issue!
2014 New Holland T8.360 MFWD Tractor (A52128)
2014 New Holland...
NEW HOLLAND TS6.130 TRACTOR (A51406)
NEW HOLLAND...
Kraus Drive Over Fertilizer Conveyor (A50514)
Kraus Drive Over...
2003 INTERNATIONAL 4300 BOX TRUCK (A51219)
2003 INTERNATIONAL...
2006 Chevy Trailblazer (A47384)
2006 Chevy...
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A51222)
2005 PETERBILT 357...
